packetizer not registered in OmniPCX record
Htc
Post by Htc »
hi
We have 5 OXE that are active in a same network. We also have a OmniPCX recorder v2.3 . each of the OXE have a packetizer with a PCM-2 card . Now the problem is : in the OmniPCX record all OXE are registered statuse , but only one or two pectizers are in registered statuse (green color) and other packetizers is in unregister statuse(red color). But this statuse for aspecific packetizer is not always red, and every time the recorder is reset, some pectizers turn green and others turn red. But every pectizer who is red if lonely added
to OmniPCX record registered without any problem and show by green statuse. Is there a limitation in using the packtizer or is there another problem?
turn on recorder :
packetizer A is registered
packetizer B is unregistered
packetizer C is unregistered
packetizer D is unregistered
packetizer E is unregistered
after reset
packetizer A is unregistered
packetizer B is registered
packetizer C is registered
reset
packetizer E is registered
all oxe-oxr-packetizer are in same vlan
all oxe are same ops
Re: packetizer not registered in OmniPCX record
Definitely open a case with ALE. They'll be able to help. Please share your solution :)
Return to “OmniPCX Record”
