No login prompt via serial console
ferby09
Post by ferby09 »
Greetings,
I've bought an used OS6350-P24 and it works out of the box. But if I try to login via serial console to activate a GUI (there is one, right?), I don't get a login prompt, it's just the cursor.
If I restart the switch with serial connected I get the following output:
General initialization - Version: 1.0.0
Serdes initialization - Version: 1.0.2
PEX: pexIdx 0, detected no link
DDR3 Training Sequence - Ver TIP-1.27.0
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
AOS BootSelector Version: 1.0
Creation Date: Aug  2 2017 03:06:04.
FfxReaderIoCreate() Initialization complete
Press x to choose XMODEM...
Press s to STOP AT MINIBOOT...
Reading kf3miniboot.bs from /boot ...done:
1572800
Uncompressed kf3miniboot.bs @ 0xA10000...
Running Miniboot...
Detected board RD-XC3-48G4XG-A
Detected DRAM size 256MB
TWSI init Channel 0....... Done. Actual freq = 96153Hz
Ctrl env init....... Done.
CP15 mrvl dbgr  0x00010987
CP15 mrvl dbgr2 0x6A008208
CP15 mrvl ctrl  0x00000030
CP15 mrvl ctrl  0x000000B0
CPU if init......... Done.
Memory on board initialized .
Detect:  Tclk    200MHz
         SysClk  800MHz
         L2Clk   200MHz
         pClk    800MHz
Marvell Controller initialization Done.
Micron 1Gb 8bit ABAEA NAND Flash detected
DRAM int Ctrl....... Done
NETA Err int Ctrl... Done
GPIO int Ctrl....... Done
PCI int Ctrl........ Done
PCI-E 0: Detected No Link.
USB0 init........... Done. DEVICE type selected
USB Err int Ctrl.... Done
XOR Err int Ctrl.... Done
XOR init............ Done
mvCtrlInit2......... done
PCI auto config. done
USB2 Host Stack Initialized.
USB Hub Driver Initialized
USBD  Wind River Systems, Inc. 560 Initialized
Non-PCI USB device found: pgmIf=0xa0, idx=0 (0), baseAddr=0xf1050100, irq=45, swapFunc=0xa1b17c
EHCI Controller found.
Waiting to attach to USBD...Done.
0xffffe50 (tRootTask): usbBulkDevInit() returned OK
usbCbiUfiDevInit() returned OK
CBI Class Driver Successfully Initialized
CS EEPROM Module ID: 420122c1 , System type: 6350 24 Copper, 4 fixed fiber POE
System Configuration
BSP Ver: 1.2/1.0.3_T6   Creation date: May 10 2016, 08:51:21
CHIP   : Alleycat3
CPU    : Marvell PJ4B (584) v7 (Rev 2)
BOARD  : RD-XC3-48G4XG-A (0x0)
CLOCKs : tClk  =  200MHz, sysClk =  800MHz
         L2Clk =  200MHz  pClk   =  800MHz
NAT_SUPPORT         = Disabled
VFP_SUPPORT         = Disabled
IO coherency        = Disabled
Target Name: vxTarget
Attaching network interface lo0... done.
Adding 8003 symbols for standalone.
Boot parameters are:
 'flash(0,0)cmm:default e=10.4.50.165:ff000000 g=10.4.50.5 u=admin pw=switch cb=9600 cp=none cs=1 cw=8 cm=modemControlOff'
AOS miniboot version: 6.7.1.54.R02
VxWorks (for RD-XC3-48G4XG-A ARMARCH V7 BE8 MMU ARCH 7) version VxWorks5.5.1
KERNEL: WIND version 2.6
Made on May 10 2016, 08:51:21.
Copyright Wind River Systems, Inc., 1984-2006
CPU: RD-XC3-48G4XG-A ARMARCH V7 BE8 MMU ARCH 7.  Processor #0.
Memory Size: 256 MBytes.  BSP version 1.2/1.0.3_T6.
Portions of code copyrighted by Agranat Systems, Inc.  All Rights reserved
Portions of code copyrighted by ALE USA Inc., 2015. All Rights reserved
Portions of code copyrighted by Alcatel Internetworking, Inc. 1994-2014.  All Rights reserved
Portions of code copyrighted by Apptitude, Inc. 1997-1999.  All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991.  All rights reserved
Portions of code copyrighted by The OpenLDAP Foundation 1999-2000.  All rights reserved
Portions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999.  All Rights reserved
Portions of code copyrighted by RSA Security, Inc.  All Rights reserved
Portions of code copyrighted by Sun Microsystems, Inc.  All Rights reserved
Portions of code copyrighted by Wind River Systems, Inc.  All Rights reserved
Portions of code developed by the Carnegie-Mellon University.
IP input maximum queue length = 50
Arp input maximum queue length = 50
New IP input maximum queue length = 512
New Arp input maximum queue length = 512
CHIP   : Alleycat3
Primary BootSelector Verification OK
Attempting to load from the CERTIFIED directory...
Loading kernel from '/flash/certified/KF3os.img'...
9538293
Detect:  Tclk    200MHz
         SysClk  800MHz
         L2Clk   200MHz
         pClk    800MHz
Non-PCI USB device found: pgmIf=0xa0, idx=0 (0), baseAddr=0xf1050100, irq=45, swapFunc=0x10b17c
BSP Ver: 1.2/1.0.3_T6   Creation date: Sep  4 2020, 08:38:11
CHIP   : Alleycat3
Write Protecting exception Vectors
 Write protecting KFos .text sections (0x100000 to 0x71a000)  1562 pages
Adding 18084 symbols for standalone.
flash(0,0)cmm:default e=10.4.50.165:ff000000 g=10.4.50.5 u=admin cb=9600 cp=none cs=1 cw=8 cm=modemControlOff
AOS kernel version: 6.7.2.122.R08
Made on Sep  4 2020, 08:38:11.
CHIP   : Alleycat3
The current date and time is:
Coordinated Universal Time (UTC): FRI JAN 14 19:29:37 2000
Local time: FRI JAN 14 19:29:37 2000 UTC
Starting dynamic software load from '/flash/certified/'...
FRI JAN 14 19:29:49 : SYSTEM (75) info message:
+++ Switch Logging device '/dev/console' enabled for output
FRI JAN 14 19:29:49 : CSM-CHASSIS (103) info message:
+++ == CSM == === Chassis Supervision Starting Up ===
sysStartWatchdog() Starting watchdog timer to INTERRUPT after 240 secs.
FRI JAN 14 19:30:00 : CSM-CHASSIS (103) info message:
+++ == CSM == APP MONITORING ON
+++ == CSM == ===== THIS STACK(1) IS PRIMARY =====
FRI JAN 14 19:30:13 : HSM-CHASSIS (101) info message:
+++ T1:Ni Insertion detected on slot 1
FRI JAN 14 19:30:16 : HSM-CHASSIS (101) info message:
+++ ==== HSM === Power Supply 1 is OPERATIONAL
FRI JAN 14 19:30:35 : INTERFACE (6) info message:
+++ NISUP boot type: cold
FRI JAN 14 19:30:38 : CLOUD-AGENT (167) error message:
+++ cldAgentCmdSigningCertOps: Failed to verify '/flash/switch/cloud/cmdObjectSignin
+++ [Count.]g.crt' against CA chain '/flash/switch/cloud/publicCAchain.pem'
+++ cldAgentMain: Failed to get public key from '/flash/switch/cloud/cmdObjectSignin
+++ [Count.]g.crt'
FRI JAN 14 19:30:40 : WEB (69) info message:
+++ WebView SSL/RSA file-based certificate set-up successful!
CS_START_END_APPLI received
====================Running in Working====================
AOS software not changed from 6.7.2.122.R08 after last reload
FRI JAN 14 19:30:49 : CCM-CHASSIS (100) info message:
+++ boot type message from slot 1 NISUP, boot type 0
FRI JAN 14 19:30:52 : CCM-CHASSIS (100) info message:
+++ === CCM === csCcmEoicFunc: send CCM_CSM_EOIC OK
FRI JAN 14 19:30:56 : CSM-CHASSIS (103) info message:
+++ == CSM == CMM startup completed
FRI JAN 14 19:30:56 : CLI (67) info message:
+++ Starting new CLI console session
login :
Successfully sent the I2C read message to NISUP!!
FRI JAN 14 19:31:16 : INTERFACE (6) info message:
+++  NIs are ready
FRI JAN 14 19:31:16 : LANPOWER (108) info message:
+++ Starting daughter module in slot 1!
Nothing else happens after that.
Any help is appreciated!
Gleylancer
Re: No login prompt via serial console
Post by Gleylancer »
I can see "login :" in the log. Maybe press enter?
ferby09
Post by ferby09 »
I've already tried pressing enter, typing admin but it doesn't react at all.
Should I reset the switch again? It should be possible via Miniboot, right?
I'm using putty at baudrate 9600 btw.
depending of your usb-to-serial-adapter you need sometimes to change the flow control (XON/XOFF or RTS....) - please try something there.
Konstantinos.E
Post by Konstantinos.E »
try 115200
Alca_holic
ferby09
Post by ferby09 »
Thank you for your tips!
I've managed to communicate via serial in putty with baudrate 9600.
I had to change some settings in the Windows device manager for my serial adapter:
baudrate 9600
data bits 8
parity none
stop bits 1
flow control xon/xoff
flow control was set to none before. When I changed settings in putty for flow control and/or baudrate it didn't work.
However, I still can't login...
The switch should be reset but admin/switch as username/password gives me the following error message:
TUE MAR 14 18:14:25 : SESSION (71) info message:
+++ [SES] Authentication failed: Session 0, access type Console
+++ [SES] Session 0, user "admin"
+++ [SES] Session 0, IP address 0.0.0.0
Authentication failure.
I've already tried resetting the switch in miniboot by deleting boot.cfg from working and certified folders.
Resetting the password didn't work either when I deleted userTable6 (userTable5 doesn't exist) from network folder.
Thank you for your help so far!
dnsleepless
Post by dnsleepless »
Did you get sorted out here? I can help you out, I've done this several times with various Alcatel OS6350 and 6450 switches. Let me know.
ferby09
Post by ferby09 »
I'm still struggling. I'd appreciate your help!
you need to delete the newes usertable within the switch folder.
ferby09
Post by ferby09 »
Sorry for the late reply but I've been busy with other projects so I put it aside.
Deleting the user table with the highest number worked!
Thank you for your help!
Return to “OmniSwitch 6350”
