Dear Support Team.
I had a OS6560 switch which I want to use as a Core switch. I want to configure NAT so that internal network get access to the external network.
Currently the users are getting IP address from ONT provided by the ISP. I had to create multiple VLANs so that traffic from all the VLAN can go to internet. I don't have Firewall/Router to implement NAT due to which I am using this OS6560 switch.
Kindly guide me accordingly.
OS6560-48X4 8.6.289.R01 GA NAT Setup
- Gleylancer
Re: OS6560-48X4 8.6.289.R01 GA NAT Setup
I do not think this is possible. After all, it's a switch, not a router.
Dear Gleylancer.
I had seen the post where it shows how to do NAT. The link is below:
https://www.alcatelunleashed.com/viewtopic.php?t=23325
I tried and follow the same steps, but the switches are on latest firmware that is why they are not accepting the commands mentioned in the link.
So if there are other commands please do share here.
NAT is not possible (in my opinion based on hardware). Also in the 6450 (old switch) there are only limited NAT features. You need a router or firewall to do NAT.
BR Silvio
BR Silvio
