"show qos queue" does not increase traffic by queues
Locked
xuan
Post by xuan »
Description: Alcatel-Lucent Enterprise OS6350-P10 6.7.2.113.R05 GA, December 06, 2018.,
For the attached model and realese, is there any known problem that causes the traffic by queues on the ports to not increase?
show qos queue 1/1
Slot/ Q Bandwidth Packets
Port VPN No Pri Wt Min Max Xmit Drop Type
1/1 0 0 - 4 - - 0 0 WRR
1/1 0 1 - 1 - - 0 0 WRR
1/1 0 2 - 1 - - 0 0 WRR
1/1 0 3 - 1 - - 0 0 WRR
1/1 0 4 - 1 - - 0 0 WRR
1/1 0 5 5 - - - 0 0 PRI
1/1 0 6 - 1 - - 0 0 WRR
1/1 0 7 - 15 - - 0 0 WRR
Thanks in advance
Re: "show qos queue" does not increase traffic by queues
because this is the 6350.... all other (more expensive) switches show there an output.
BR Silvio
xuan
Post by xuan »
Hi Silvio,
sorry but your answer does not convince me
In this other equipment:
Description: Alcatel-Lucent OS6250-P24 6.7.1.146.R01 GA
This inferior model and version does increase the traffic in the queues. Does not present this problem
show qos queue 1/1
1/1 0 0 - 10 - - 11408692 182028 WRR
1/1 0 3 - 1 - - 223 0 WRR
1/1 0 4 - 1 - - 14 0 WRR
1/1 0 5 5 - - - 158289 0 PRI
1/1 0 6 - 1 - - 19558 0 WRR
1/1 0 7 7 - - - 5041163 0 PRI
I'm still wondering if it won't be a problem with the software version 6.7.2.113.R05.
Thanks in advance
xuan
Post by xuan »
Hi guys,
I already have the answer.
In the CLI Reference Guide 6.7.2.R08
"In OmniSwitch 6350, Xmit/Drop counters will not be updated in the command output"
In the CLI Reference Guide 6.7.1, it does not indicate the above limitation.
I close the thread
Thank you all for your patience with me.
Locked
Return to “OmniSwitch 6350”
