Mounting bracket for 6450-P10
AUautodc
Post by AUautodc »
Hello everyone. I have several of the 6450-P10 that I need to mount under the desks and/or wall. I usually use the mounting bracket for the 6450-P24 or 6450-P48 for this. Unfortunately, I cannot find it online anymore. I understand that these brackets also come with the 6560 but I cannot find it online to purchase (just the brackets only). Any suggestions?
Re: Mounting bracket for 6450-P10
The 6450 is end of sales since more than one year. But you can use all brackets for 6360-(P)10 and 6465T-(P)12. They use the same chassis like 6450-P10.
AUautodc
Post by AUautodc »
Thank you silvio. I am out of extra brackets of the old models. I cannot find the model number for the extra brackets for the new models. Do you know what this model number is if I want to order extra brackets that comes with the 6560-P24?
for the most of the "new" 19"-switches (so for the 6560) there is a part# since some month: OS-FRBK-MNT
Return to “OmniSwitch 6450”
