i am trying to upgrade firmware on some wireless devics 8158s in the network.
I have downloaded the appropritate firmware file.
How can I use OXO as the TFTP server to upgrade the devices?
thank you
OXO as TFTP servr
Perceval
Re: OXO as TFTP servr
On these models, it should be done automatically (it did it on my setup, it does it on Connect R2.0+ or R10.3 and previous versions, as stated in the doc), since your 8158s needs to connect to your OXO, which is the TFTP server (otherwise, you'd get the error "no response from the TFTP server").
You can check if everything is fine by aborting the phone boot process to check if the TFTP server is address correct.
I don't think you need to change anything in Oxo Connect, but there's a Download item (sorry, I have the French version so I can't tell you eaxctly what's written, it's a yellow "bean" with a white arrow on the top left), where there's a "Download terminal" thing you can use, then a instant download force the 8xxx phones to update.
I didn't have to download anything on the Oxo.
Hope this helps !
Hope this helps !
slaskaridis
can you send it to me please?
i speak french also
i speak french also
Perceval
In OMC, it's "Sauvegarde des données & Basculement" >> "Téléchargement des terminaux" >> "Téléchargement immédiat" (OK).
When I was trying to manually upgrade my 8078s, the OXO did it for me. Nice !
If it does not work, try to remove the battery to force-reconnect the phone, I don't think there's more to do...
slaskaridis
I found the setting. My setting is "No downloadng".
I will try this onsite and post the result.
Thank you.
Thank you.
