Unable to connect to my switch in ssh from my Omnivista
Aimad
Post by Aimad »
Hello
I have an issue with few switchs in Release 8.8 (I try with 8.8 R01 and 8.8 R02)
When I try to connect to my switch in ssh from my Omnivista I cannot.
I have an error message "wrong username and password".
But i have no issue when i try to connect them in ssh from putty.
But I have no issues with my switch in release 8.7 with my Omnivista.
I can connect them from Omnivista
Switchs in 8.7 and 8.8 are same / same configuration / same user / same radius behind.
Do you know how to resolve this issue ?
Re: Unable to connect to my switch in ssh from my Omnivista
You have opened the question in a very old OV-release. If you realy have this old one I assume the ssh version is not supported at the new switches anymore.
BR Silvio
Return to “OmniVista 2500/2700 v3.4 and older”
