How to remove secondary-config? (7705 SAR-A)
config_tea
Post by config_tea »
I'm trying to load this password-protected unit with the default user/password of admin/admin.
I can specify the primary-config url as "none" after I interrupt the boot process, but there seems to be no option to remove the secondary-config, meaning the unit will still boot up with an old unknown password.
Is there an equivalent of a boot loader or rommon/shell that I can boot into instead?
Also: these units are riveted shut! I cannot access the compact flash.
Thanks for any suggestions!
config_tea
Re: How to remove secondary-config? (7705 SAR-A)
SOLUTION:
Use TFTP server - IP address (for example) 192.168.0.10
Create blank text file called "config.cfg" in the TFTP root folder
Connect MGMT port to TFTP server (MGMT port IP will be assigned shortly)
INTERRUPT THE BOOT PROCESS:
Hit a key within 3 seconds to change boot parameters…
Type "sros" and hit ENTER within 29 seconds to begin changing parameters: sros
You must supply some required Boot Options. At any prompt, you can type:
"restart" - restart the query mode.
"reboot" - reboot.
"exit" - boot with existing values.
Press ENTER to begin, or 'flash' to enter firmware update… <ENTER>
Software Location
You must enter the URL of the TiMOS software.
The location can be on a Compact Flash device,
or on the network.
Here are some examples
cf3:/timos1.0R1
ftp://user:passwd@192.168.1.150/./timos1.0R1
ftp://user:passwd@[3FFE::1]/./timos1.0R1
tftp://192.168.1.150/./timos1.0R1
tftp://[3FFE::1]/./timos1.0R1
The existing Image URL is 'cf3:\TiMOS-B-8.0.R10'
Press ENTER to keep it.
Software Image URL: <ENTER>
Using: 'cf3:\TiMOS-B-8.0.R10'
Auto-Discovery
This system is equipped with TiMOS
Auto-Discovery.
Would you like to enable auto-discovery? (yes/no) no
SET CONFIG FILE LOCATION AS TFTP ROOT FOLDER:
Configuration File Location
You must enter the location of configuration
file to be used by TiMOS. The file can be on
a Compact Flash device, or on the network.
cf1:/config.cfg
ftp://user:passwd@192.168.1.150/./config.cfg
ftp://user:passwd@[3FFE::1]/./config.cfg
tftp://192.168.1.150/./config.cfg
tftp://[3FFE::1]/./config.cfg
Config File URL: tftp://192.168.0.10/config.cfg
CONFIGURE MGMT PORT IP ADDRESS:
Network Configuration
You specified a network location for either the
software or the configuration file. You need to
assign an IP(v6) address for this system.
The IP address should be entered in standard
dotted decimal form with a network length.
example: 192.168.1.169/24
Enter Active IP Address (Type 0 if none desired): 192.168.0.11/24
In case of an IPv6, the IPv6 address should be
entered in standard colon hexadecimal notation
with a prefix length.
example: 3FFE::1/112
Enter Active IPv6 Address (Type 0 if none desired): 0
No Active IPv6 Address configured
Would you like to add a static route? (yes/no) no
The existing fips-140-2 configuration is : 'no fips-140-2'
If you would like to change it please enter 'fips-140-2' followed by ENTER
or press ENTER to keep existing fips configuration <ENTER>
New Settings
primary-image cf3:\TiMOS-B-8.0.R10
primary-config tftp://192.168.0.10/config.cfg
secondary-image cf3:\7705-TiMOS-6.0.R4
secondary-config cf3:\7705-TiMOS-6.0.R4\config.cfg
address 192.168.0.11/24 active
autonegotiate
duplex full
speed 100
wait 3
persist on
no fips-140-2
console-speed 115200
Do you want to overwrite cf3:/bof.cfg with the new settings? (yes/no): yes
Login with admin/admin
Delete old config files and edit bof.cfg with the vi editor
Return to “7705 SAR”
