aos 860 to use dhcp for wan and nat an internal lan
jpazarena
Post by jpazarena »
I wonder if anyone would share what it takes to turn a 6860 into a natted router ?
I have dhcp enabled on the wan feed of the 6860 , which appears to auto configure a default gateway .
I have an internal "lan" vlan configured ( do not need the 6860 to offer dhcp server IPs )
I do however need it to nat the internal IPs just like a cheap old $50 router .
An example of the proper CLI commands would be most appreciated .
Re: aos 860 to use dhcp for wan and nat an internal lan
NAT is not possible.
