i have a Alcatel Omnipcx Enterprice from one of our customers. But i have no idea how i should configure it.
Alize BIOS Monitor
*** BIOS Version 3EH30227ALAC bios100/011.003 ***
*** Generated on Dec/16/2008 at 11:27 ***
I try OMC 51.0.8.1 but i cant connect. (final product ist turned to OXO connect R1-R51 ADE100)
PC over Switch in (Gateway driver Processing Unit) Port LAN
Config Cable on Config Port
I can see the ip of the Unit, but when i turned my PC in the same IP Range i cant ping it and i cant connect to the pbx via OMC.
What is wrong?
Beginners Question
Re: Beginners Question
At first - we talk about OXO (and OMC) or about Enterprise (and telnet connection with CS).
Telefonguy
Oh, i see my mistake. You are correct this one is a Enterprise. So i have to use the CS.
and how did u get those info if you aren't connected to the box
Alize BIOS Monitor
Alize BIOS Monitor
indded vad that should serial connection , so he can start from here
about that bios message i don't know if it's cs bios or gd , if cs he has to boot the system and manage his pc @ipadress to trust list and eventually routing to get connection and let oxe to response to its telnet requests
From start post "Config Cable on Config Port"haroun wrote: ↑21 Jun 2022 09:15 indded vad that should serial connection , so he can start from here
So I think that in the begining TC start works with OXE like with OXO. I hope - he has no problem now.
