List of forwarded numbers
edi123
Post by edi123 »
How can I get a list of "overflow on associate" numbers overflowed to a particular extension ?
This is for overflow on associate + true
Eg : ext A overflow to ext Z
ext B overflow to ext Z
ext C overflow to ext Z
I need the list : A,B,C
Many thanks...
Re: List of forwarded numbers
F.e. if you have OmniVista - export Users. And search in txt file what you need.
edi123
Post by edi123 »
vad wrote: 24 Mar 2022 23:38 F.e. if you have OmniVista - export Users. And search in txt file what you need.
Thanks for the reply...but this doesn't give what I am looking for.
I need a list of extensions that are overflown to this number...
listfwd is suppose to give a list of forwarded numbers...
Something like that...many thanks...
When you export Users (with Dynamic state user) - why you cannot search where present assocoated number what you need?
edi123
Post by edi123 »
vad wrote: 28 Mar 2022 23:29 When you export Users (with Dynamic state user) - why you cannot search where present assocoated number what you need?
When the user is exported, in Dynamic State User is shows the number it is forwarding to,
My number : 3511 and I have No forward that to any number and overflown to 3566 when no answer...So, the exported file shows these information.
What I need is a list of numbers that are overflown to my number.
Eg : My number is 3511
Alex's number 3522 and it is overflown to my number 3511
Matt's number 3524 and it is overflown to my number 3511
Peter's number 3584 and it is overflown to my number 3511
I need the list of the numbers overflown to my number 3522,3524,3584...
Return to “Users”
