SW Upgrade error - OXO
Alcatracer
Post by Alcatracer »
Hi all,
Tried to upgrade a OXO from R4 to R5 (R050_038_001).
When starting software download I get this message;
"no left space (blocks) on target. avail 186238 required: 430108 ... Session aborted"
Is there a way to flash memory on the system?
Was hoping that I could use the "Clean" button in the software download window, but this function is not available (grey), why?
Have tried cold reset, factory reset, and I have taken out CPU and battery, but still the same.
Anyone seen the same?
Thanks.
Re: SW Upgrade error - OXO
It's most likely the space on the flash.
Do you have ton of voicemail and/or VG Saves already?
Return to “GENERAL”
