UNP and default Vlan
Hi All
I have question regarding UNP and default Vlan on member port
SW03-> show vlan members port 1/1/1
vlan type status
112 unpUntag forwarding
219 default forwarding
unp profile "VLAN112DATA"
unp port 1/1/1 port-type bridge
unp port 1/1/1 port-template VLAN112DATA
Port 1/1/1 has a UNP profile and template to vlan 112. it appear under port 1/1/1 as UNPuntag. when I assign Vlan 219 as a default vlan for port 1/1/1 I couldn't reach any host configured with an IP address under vlan 219, unless I totally disable and remove the UNP profile for vlan 112.
vlan type status
Re: UNP and default Vlan
configure an unp profile mapped to vlan 219 and set it as the default-unp-profile for all ports (or via template).
Best regards
Best regards
Hi Silvio
Thank you for the reply and sorry for the delay. I will give it a try later. Many thanks for your time!
Hi Silvio
I was wondering if you are kind enough to show me a example configure how we can set a vlan as a default UNP profile for all the port on the switch? Thank you very much!
unp profile "VLAN219"
unp profile "VLAN219" map vlan 219
unp port port-template VLAN112DATA default-profile VLAN219
Hi Silvio
Thank you very much for the assistance!
Hi @All
konfig:
result:
my humble expectation was: the mac of the untagged device at port 1/1/1 is learned in Vlan1065 instead of Vlan1
... but it's not ... so this can't be the right config for my intentions
hints ?
konfig:
unp port-template microSensDwnLnk
unp port-template microSensDwnLnk vlan 1065
unp port-template microSensDwnLnk vlan 1067 tagged
unp port-template microSensDwnLnk vlan 1130 tagged
unp port 1/1/1 port-template microSensDwnLnk
result:
OS# show mac-learning
Legend: Mac Address: * = address not valid,
Mac Address: & = duplicate static address,
Domain Vlan/SrvcId[ISId/vnId] Mac Address Type Operation Interface
VLAN 1 00:60:a7:0c:77:1e dynamic filtering 1/1/1
hints ?
! DA-UNP:
unp profile "unp-v1065"
unp profile "unp-v1065" map vlan 1065
unp port-template microSensDwnLnk direction both default-profile "unp-v1065" classification trust-tag ap-mode admin-state enable
OS# show mac-learning | grep 1/1/1
VLAN 1065 00:60:a7:0c:77:1e dynamic bridging 1/1/1
OS#
this works for Vlan 1065 ... but is this the right way ?
This lines have a complete different function. You can delete them:
You need classification rules to forward clients into the correct profile. All other devices (where the rule isn't matching) will go to the default-profile (this is your case now). Use the command "show unp user" and "show unp user detail" for troubleshooting.
BR Silvio
BR Silvio
