Hi All
I have Alcatel OXE cyrstal HW , CPU-7 , Release 9.0 , after an electricity problem , the system was crash, when try to login I get:
Welcome to gcc
Alcatel-Lucent OmniPCX Enterprise
login: mtcl
Password:
standard installation last performed: 24-Feb-2006 03:33:03
No directory /DHS3bin/mtcl!
Logging in with home = "/".
dumpsave: Cannot open kernel map file /boot/System.map
open: Too many levels of symbolic links
-bash-2.05b$
I try to reinstall new system. But when I try to login console via direct serial connection , I couldn't get any output on Hyper Terminal during booting.
after the CPU had completed the booting then I get login only:
login:
I try two console cables , try putty app. the same issue
Is there any advice to solve this problem to be able access to CPU during boot to for doing the necessary steps for new release installation.
No output on Hyper Terminal during CPU-7 booting.
Re: No output on Hyper Terminal during CPU-7 booting.
May be you use COM B instead of COM A?
Sam2009
thanks vad
yes I used B0, because A0 didn't work
Sam2009
I use CPU/CBRMA cable 3BA 28040 xx to connect CPU with CBRMA Box
- frank
Did you try another CPU with another HD by any chance?
