Dears,
I tried to install OXE 12.4 on HP server proliant DL20 Gen9 by using SOT. The installation complete as per SOT message. On the other hand, when server switched on the below message appear
"attempting boot from hard drive (c:) "
Grub loading stage 2. output on the serial line ..
Thanks in Advance
Adel
standard installation oxe 12.4 version M5.20480f
Re: standard installation oxe 12.4 version M5.20480f
did you do all the steps that are explained in this document? => oxe12.4_im_ApplianceServer_8AL91029USAI_3_en.pdf
yes, i tried to install it by using SOT and PC installer but it gives same error
hi,
I am held up at SOT. i have never used it and thought of never using it, but it seems for the latest R100 i need it. im stuck at creaating a templace or creating a media,
this is my NFS
//192.168.10.1/dhs3mgr ( its the ip of my pc and folder) this folder is created in I: drive.
when i click on creat i get an error
"the storage is successfully created but with following error:
- nfs mount search on 192.168.10.1 failed.
Check the storage path or the network.''
can some one help me on this,,
thanks in advance guys
morio
this is my NFS
morio
