lanpower Chassis 1 or Slot 1 does not exist
ramyrez
Post by ramyrez »
hi everyone! well
I have problem guys when I try to enable lanpower it shows me this message below :
lanpower slot 1/1 service start
ERROR: Chassis 1 or Slot 1 does not exist
lanpower port 1/1/1-8 admin-state enable
but when I try to give VLAN members port it doesn't give me an error
like this command: vlan 1 members port 1/1/1-8 untagged
It works fine but in lanpower command, it shows me an error
Thanks in advance
Re: lanpower Chassis 1 or Slot 1 does not exist
what is the output of:
show cmm
show virtual-chassis topology
best regards
ramyrez
Post by ramyrez »
hi silvio
FYI,the output of:
show cmm
Chassis ID 1 Module in slot CMM-A
  Model Name:                    OS6860-24,
  Module Type:                   0x6062201,
  Description:                   24 G 4 10G,
  Part Number:                   904062-90,
  Hardware Revision:             01,
  Serial Number:                 Y0381521,
  Manufacture Date:              Jan 19 2019,
  FPGA 1:                        0.9
  Admin Status:                  POWER ON,
  Operational Status:            UP,
  Max Power:                     46,
  CPU Model Type:                 Helix4,
  MAC Address:                   2c:fa:a2:f7:b2:cd,
Legend: Status suffix "+" means an added unit after last saved topology
Local Chassis: 1
 Oper                                   Config   Oper
 Chas  Role         Status              Chas ID  Pri   Group  MAC-Address
 1     Master       Running             1        100   205    2c:fa:a2:f7:b2:cd
OS6860-24 isn't a poe-switch. You need P24.
best regards
