specific ringtone for a contaact
steph31570
Post by steph31570 »
hello,
i try do configure a specific ringtone for a contact on 8028s phone.
I see it's possible to have different ringtone between internal or external call but i d'ont see anywhere the possibility to fix a different song for one contact.
If you have a solution i will be happy ;-)
BR
sadim
Re: specific ringtone for a contaact
Post by sadim »
Since it is a 8/9 Series Phone, It should be possible.
Check the pdf file that you can download from the BPWS 8AL91003USAK (UserServices), chapter 54.3.2 - Ring Types
BRegards
Return to “Alcatel-Lucent Series 8&9”
