upgrade from 8.5 to 8.7.1 question !!
oysterliu
Post by oysterliu »
I upgrade my os6860e from the 8.5 to 8.7.1 . and reload from working is ok. But I set the "aaa switch-access mode enhance" before I create the user config-mode-user. So, I could not config this switch anymore.
I turn off the power and turn on it again. It is running at Certified with 8.5 . I try to change the "aaa switch-access mode default" and "copy certified working" and "modify running-director working". The switch's setting is ok and running ok. But, I try to upgrade firmware from 8.5 to 8.7.1. I finished the image upload and check the microcode by "microcode working" that show the correct version. Then, I reload the switch by command "reload from working no rollback-timeout".
After switch reboot, I check the switch loaded image is 8.5 and running directory is Certified. I check the the log, it had some warning information.
2021 Sep 17 09:31:25.305 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: vcReloadMgrVCSplitQuery: status 3 imageDir working index 0
2021 Sep 17 09:31:25.305 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: vcReloadMgrVCSplitQuery: reloading all chassis
2021 Sep 17 09:31:25.307 OS6860 swlogd MIP_GATEWAY mipgwd INFO: ---- Logging MIP_SET type, command to be sent:
2021 Sep 17 09:31:25.307 OS6860 swlogd MIP_GATEWAY mipgwd INFO: MIP_SETF(14) msg_id(31522831) (APPID_CLI(67/0) -> APPID_CHASSISUPER(64)) values:
2021 Sep 17 09:31:25.307 OS6860 swlogd MIP_GATEWAY mipgwd INFO: Table(65555/0): chasGlobalControl
2021 Sep 17 09:31:25.307 OS6860 swlogd MIP_GATEWAY mipgwd INFO: Index: 0
2021 Sep 17 09:31:25.308 OS6860 swlogd MIP_GATEWAY mipgwd INFO: Object(8) Name: chasGlobalControlConfirmOperation
2021 Sep 17 09:31:25.308 OS6860 swlogd MIP_GATEWAY mipgwd INFO: Object Value(int32): 1
2021 Sep 17 09:31:25.308 OS6860 swlogd MIP_GATEWAY mipgwd INFO: ----------------
2021 Sep 17 09:31:25.308 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: vcReloadMgrReloadVC: starting reload sequence for image working
2021 Sep 17 09:31:25.325 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: vcReloadMgrReloadVC:: calling vc reload state machine
2021 Sep 17 09:31:25.325 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: stateMachine: entry state 0 (vcReloadIdle) event 0 (vcReloadStartEvt)
2021 Sep 17 09:31:25.325 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: startFlashSync: starting flash sync on master chassis before reload
2021 Sep 17 09:31:25.325 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: changeState: new state is vcReloadMasterSync
2021 Sep 17 09:31:25.325 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: vcReloadMgrReloadVC: line 1334 - result is DEFERRED
2021 Sep 17 09:31:25.887 OS6860 swlogd flashManager FlashMgr Main INFO: flashMgrThreadSyncAndInvalidate: cache invalidated in preparation for file verifications
2021 Sep 17 09:31:30.888 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: vcReloadSyncCallback: sync complete - error 02021 Sep 17 09:31:30.888 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: stateMachine: entry state 1 (vcReloadMasterSync) event 2 (vcReloadMasterSyncCompleteEvt)
2021 Sep 17 09:31:30.888 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: startImageValidation: starting image validation working - reset list is -1
2021 Sep 17 09:31:30.888 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: startImageValidation: sending reload command to chassis 1 slot 65
2021 Sep 17 09:31:30.888 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: startImageValidation: chassis 2 slot 66 not connected
2021 Sep 17 09:31:30.888 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: startImageValidation: chassis 3 slot 66 not connected
2021 Sep 17 09:31:30.888 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: startImageValidation: chassis 4 slot 66 not connected
2021 Sep 17 09:31:30.888 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: startImageValidation: chassis 5 slot 66 not connected
2021 Sep 17 09:31:30.888 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: startImageValidation: chassis 6 slot 66 not connected
2021 Sep 17 09:31:30.888 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: startImageValidation: chassis 7 slot 66 not connected
2021 Sep 17 09:31:30.888 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: startImageValidation: chassis 8 slot 66 not connected
2021 Sep 17 09:31:30.888 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: startImageValidation: pending list after processing 2
2021 Sep 17 09:31:30.888 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: changeState: new state is vcReloadVerify
2021 Sep 17 09:31:30.889 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: processMipResult: line 184 - result is DEFERRED mip result pending is 1
2021 Sep 17 09:31:30.889 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: vcReloadMgrRcvCallback: chassis 1 slot 65 msg->type 0
2021 Sep 17 09:31:30.889 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: vcReloadMgrRcvCallback: chassis 1 slot 65 reload img working
2021 Sep 17 09:31:30.889 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: vcReloadMgrRcvCallback: rollback time 0 redundancy time 2
2021 Sep 17 09:31:30.889 OS6860 swlogd ChassisSupervisor reloadMgr INFO: reloadMgrStateMachine (2300): Machine type Primary or Image state ReloadMgrIdle event ReloadMgrReloadImageEvt
2021 Sep 17 09:31:30.999 OS6860 swlogd flashManager FlashMgr Main INFO: Verifying image directory working on CMM flash
2021 Sep 17 09:31:31.182 OS6860 swlogd flashManager FlashMgr Main INFO: flashMgrThreadSyncAndInvalidate: cache invalidated in preparation for file verifications
2021 Sep 17 09:31:36.182 OS6860 swlogd flashManager FlashMgr Main INFO: flashMgrValidateImage_exec: calling system(/bin/validate_image /flash/working/Uos.img))
2021 Sep 17 09:31:45.940 OS6860 swlogd flashManager FlashMgr Main INFO: flashMgrValidateImage_exec: valid
2021 Sep 17 09:31:45.940 OS6860 swlogd flashManager FlashMgr Main INFO: flashMgrVerify: /flash/working/Urescue.img succeeded
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor reloadMgr INFO: reloadMgrVerifyCallback: error 0
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor reloadMgr INFO: reloadMgrStateMachine (2300): Machine type Primary or Image state ReloadMgrFlashVerify event ReloadMgrVerifyCompleteEvt
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: vcReloadMgrRcvCallback: chassis 1 slot 65 msg->type 1
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: vcReloadMgrRcvCallback: chassis 1 slot 65 reload status OK
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: processOpComplete: chassisID 1 pendingList 2
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: processOpComplete: chassisID 1 pendingList 0
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: stateMachine: entry state 2 (vcReloadVerify) event 4 (vcReloadVerifyCompleteEvt)
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: startSync: reset list is ffffffff
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: startSync: sending VCReloadSync to SELF 1
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: changeState: new state is vcReloadWaitSync
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: stateMachine: verify complete - reset list is ffffffff chassis ID is 1
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: stateMachine: returning MIP_DEFERRED
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: processMipResult: line 184 - result is DEFERRED mip result pending is 1
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: vcReloadMgrRcvCallback: chassis 1 slot 65 msg->type 2
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor vcReloadMgr INFO: vcReloadMgrRcvCallback: chassis 1 slot 65 reload sync
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor reloadMgr INFO: reloadMgrStateMachine (2300): Machine type Primary or Image state ReloadMgrIdle event ReloadMgrSyncEvt
2021 Sep 17 09:31:45.942 OS6860 swlogd ChassisSupervisor reloadMgr ALRT: Flash sync before reload
2021 Sep 17 09:31:45.969 OS6860 swlogd ChassisSupervisor bootMgr INFO: bootMgrSyncBeforeReboot (16201): entry - clearing saved NI poweroff flags
2021 Sep 17 09:31:45.970 OS6860 swlogd ChassisSupervisor bootMgr INFO: bootMgrNotifyVCReset: issuing VC reset notifications
2021 Sep 17 09:31:45.970 OS6860 swlogd ChassisSupervisor bootMgr INFO: bootMgrNotifyVCReset: vclib_notify_reset for 1/65 entity 0
2021 Sep 17 09:31:45.970 OS6860 swlogd ChassisSupervisor bootMgr INFO: bootMgrNotifyVCReset: acks pending 0
2021 Sep 17 09:31:45.970 OS6860 swlogd vcmCmm ipc INFO: CMM:vcmCMM_server_rx@1684: Process (notifyReset, len 28, src 0/65/37023)
2021 Sep 17 09:31:45.970 OS6860 swlogd ChassisSupervisor bootMgr INFO: _bootMgrRebootCMM: machineState is BootMgrReady powerDownNIs is 1
2021 Sep 17 09:31:45.970 OS6860 swlogd ChassisSupervisor bootMgr INFO: _bootMgrRebootCMM (13053): No reset notifications pending - proceeding with reboot
2021 Sep 17 09:31:45.970 OS6860 swlogd vcmCmm ipc INFO: CMM:vcmCMM_server_rx@1708: notifyReset (entity: 0 reset chas:slot 1/65 my chas:slot 1/65)
2021 Sep 17 09:31:45.970 OS6860 swlogd ChassisSupervisor bootMgr INFO: bootMgrShutdownUserPorts: shutting down user ports
2021 Sep 17 09:31:45.971 OS6860 swlogd ChassisSupervisor appMgr INFO: appMgrSendEvent: sending event to client /bin/etherNi event (46) data (0)
2021 Sep 17 09:31:45.971 OS6860 swlogd vcmCmm protocol INFO: CMM:vcmCMN_notify_reset_cb@17755: Process (chassis 1, mac 94:24:e1:0a:8c:77, entity 'chassis', slot 65)
2021 Sep 17 09:31:45.971 OS6860 swlogd vcmCmm ipc INFO: CMM:vcmCMN_tx_data_cb@3191: regUpdateSystem -> (chassis 0, CMM-A, port 37023, len 2748)
2021 Sep 17 09:31:45.971 OS6860 swlogd intfNi Drv INFO: niEsmShutDownPorts:WARN: Disabling ports ranged from:1 to:33
2021 Sep 17 09:31:45.971 OS6860 swlogd intfNi Drv INFO: eniPhyPortEnable(2282):IND:gport:0 1/0/8 portEnable:Disable autoNeg:Disable portAdv:0x0
2021 Sep 17 09:31:45.971 OS6860 swlogd ChassisSupervisor bootMgr ALRT: _bootMgrRebootCMM: rebooting system
2021 Sep 17 09:33:59 OS6860 syslogd started: BusyBox v1.28.4
2021 Sep 17 09:33:59.081 OS6860 kernel klogd started: BusyBox v1.28.4 (2020-10-05 23:45:29 PDT)
2021 Sep 17 09:33:59.082 OS6860 kernel [ 0.000000] Booting Linux on physical CPU 0x0
2021 Sep 17 09:33:59.082 OS6860 kernel [ 0.000000] Initializing cgroup subsys cpuset
2021 Sep 17 09:33:59.082 OS6860 kernel [ 0.000000] Linux version 3.10.104 (relman@mcgrath) (gcc version 4.8.2 (GCC) ) #1 SMP Mon Oct 5 23:40:35 PDT 2020
2021 Sep 17 09:33:59.082 OS6860 kernel [ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7d
2021 Sep 17 09:33:59.082 OS6860 kernel [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
I could not finish the firmware upgrade. Could you suggest me a method to upgrade it.
thanks!!!
Re: upgrade from 8.5 to 8.7.1 question !!
according the RN 8.6R02:
Feature Guidelines:
The following guidelines should be followed due to the introduction of config-mode in the 8.6R2 release.
1. Due to the introduction of config-mode and the new config-mode user, if the switch is running in
Enhanced Mode an AOS software upgrade is not possible from a release prior to 8.6.R02. As a
workaround, the user needs to re-enable the Default Mode, perform the software upgrade,
configure the config-mode user and then configure Enhanced Mode.
As I have done it at 8.6.R02 some years ago I haven't read the RN too and keep the mode at enhanced. So I run in the same issue like you. Onliest way to solve it was usb recovery. You can do it direct to the newest release. Than make all your configs/users again without enhanced mode. Than follow the procedure for the "new" enhanced mode (starting with 8.6R02).
