After activate clip in sli 16 1 telephone not ringing
adel_88
Post by adel_88 »
I activated clip feature for sli 16 1 but unfortunately telephone didn’t ring while all dynamic init parameters set to be 255.is anybody know values to be set in dynamic init parameters.note I can pickup call while telephone didn’t ring.
Thanks in advance
Re: After activate clip in sli 16 1 telephone not ringing
Before changing the dynamic parameters, did you check if the phone rings with a shorter pair ? Like if you connect the phone at the PBX directly rather than running a line to a distribution panel?
adel_88
Post by adel_88 »
Thanks frank
the problem solved by changing parameter. i checked old posts here and i found necessary parameters
