OmniSwitch 6850 issues connection via console port
dasSolli
Post by dasSolli »
Hello All
Info:
Used and Privat buy switch. (I don't know it is factory reseted)
Problem:
I have the problem to connect to the switch the output is always garbage. (output not readable)
I have read much forum posts off this problem. (alcatelunleashed.com)
Tests:
I have test different usb-r232 seriall dongels.
I have test different cables (rj45 to rs232).
I have test a selfmade cable from a forum post. (alcatelunleashed.com)
I have test different Devices (Win and Linux Systems).
I have test different baut. (but i now on the swicht it is default 9600)
I have test different terminal emulator z.b. putty
The default switch config is working i don't know it is a hardware problem.
Now i dont have any ideas what can be the problem or what i can test next.
How i kann make a factory reset without serial connection. (I don't know the serial port kann blockt maybe)
Sorry if anything on the post is not correct (First Post)
and Thx for all answers
language english and german
dasSolli
Re: OmniSwitch 6850 issues connection via console port
Post by dasSolli »
I test it one more time with a new kabe selfmade and now it wörks
dumca
Post by dumca »
Hi DasSolli,
I have the same problem as you.
Please can you explain to me how you managed to connect console cable to your OS6900?
Thx :)
