Change trunk port to access port
Kkuuumar
Post by Kkuuumar »
Hi, i'm using 6860E switch with AOS 8.6
May i know what is the cmd to change trunk port to access port? Thanks in advance
when i try the below cmd, having error.
->vlan 5 members port 1/1/5 untagged
ERROR: A VPA already exists for given vlan and port
Re: Change trunk port to access port
you need to delete the vlan from the port first:
no vlan 5 members port 1/1/5
Kkuuumar
Post by Kkuuumar »
It's working... Thanks Silvio! :)
