Ip Touch applications to Hotel
ana_soares
Post by ana_soares »
I am doing one ip touch application, and I have some problems that I can't resolve, because I don't find it in the documentation I have.
I have a form text for an example that have a command that should make a call. I have read some papers that said that to make that call I need to have MyPhoneApi or XmlTelephony. How can I get this API, how can I use it in C#, can you show me some sample?
Another problem is I need to send Text Messages with my application to the Phone, I need to use the same functionalty that is used to send messages by phone to another phone. I read that to do this I need to use one protocol called Pagging Interface, how can I get it.
Other thing, this is an application to a hotel and i need to send, when the client make check in, a welcome message from the hotel. did OXE sends some events when the check in is made, How can I now that someone new is at that bedroom.
Thank you for your help.
Ana Soares
Re: Ip Touch applications to Hotel
You need AHL (Alcatel Hotel Link) and XML Server, Presentation Server licenses.
Maybe Cavagnaro knows much more things about applications development. Try sending him a PM.
Regards.
Well as toten said you need licenses for MyPhone XML API, as the forms (libraries) are available on ASP, PHP and JSP I belive you can use them for your C#.
Go to http://www.applicationpartner.alcatel-lucent.com and download the examples on there.
It would be also a good idea if you can join as a developer partner to obtain more documentation.
Return to “Hotel / Hospital”
