connection to microsoft teams
Hello everyone ,
I want to know that is it possible to connect OXO or OXE to Microsoft Teams without using Rainbow?
Re: connection to microsoft teams
AFAIK the official answer is "no".
You need AudioCodes GW for that purpose(correct me if i'm wrong).
But as it is SIP-connection between two sytems you can try it on your own risk.
you can do it with an audiocodes SBC between OXE and Teams. we have done it for several customers with an m800
- tot3nkopf
Yes, use Teams Direct Routing with an SBC. Many have interworking reports and guides.
I used also Audiocodes (VE) for the ease of use - also there are guides for the integration with OXE and Teams that can help.
What is necessary to connect OXE with MS Teams: Rainbow or AudioCodecs SBC and what else should I have in my OXE (licenses, tunks etc) to do it?
- frank
It is now possible to connect Rainbow to Microsoft Team.
It just took 5 years lol...
https://www.al-enterprise.com/-/media/a ... eet-en.pdf
I use the power App in teams, and its working pretty fine. But if you want presence sync between Rainbow and Teams, you need the O2G Gateway for this
i heared today in a meeting with presales, there will be an IWR soon for an inplementation with teams directrouting, which supports sip call forking for scenarios with an alcate set and Teams direct routing... i hope the best...
