HOW TO TAKE BACKUP FOR ALCATEL OXE PABX
ogunkua
Post by ogunkua »
Dear All,
Thanks for the opportunity to share in your pool of knowledge, here. i need support on steps to taking Backup from OXE PBX.
Thanks for your time and education.
Re: HOW TO TAKE BACKUP FOR ALCATEL OXE PABX
There are some automatic backups performed each day at 5:45 morning if I'm not wrong by the oxe itself you can found them under
/usr4/BACKUP they're classified on daily basis
to get any one of them u can use any ftp connection program (pure DOS, ftp, winscp, FileZilla etc) and save it to your store box
PS use(I) binary mode transfer ;
Also by using swinst account and menu 2 you can perform an immediate backup and retrieve it as above
ogunkua
Post by ogunkua »
Dear Haroun, thanks so much. I appreciate
Oops! I totally forgot it! U can also use the management server Omnivista 4760/8770 under maintenance module to make immediate or scheduled backup/restore
ogunkua
Post by ogunkua »
Awesome. This will be useful, faster. Thanks
fery_s
Post by fery_s »
haroun wrote: 01 Jan 2021 08:26 There are some automatic backups performed each day at 5:45 morning if I'm not wrong by the oxe itself you can found them under
that is not a complete backup, it is just database and not contain voice mail and etc.
fery_s wrote: 05 Jan 2021 06:57
of corse under swinst he has to make a choice
FACILITIES Main menu Installation FACILITIES 2.67.0
1 Easy menu
2 Expert menu
Q Exit
Your choice [1..2, Q] ? 2
ALCATEL-LUCENT
FACILITIES Expert menu Installation FACILITIES 2.67.0
1 Packages installation
2 Deliveries installation
3 Cloning & duplicate operations
4 Backup & restore operations
5 OPS configuration
6 System management
7 Database tools
8 Software identity display
9 Remote download
Q Go back to previous menu
Your choice [1..9, Q] ? 4
ALCATEL-LUCENT
Backup and restore menu Installation FACILITIES 2.67.0
1 Immediate backup operations
2 Periodic backup operations
3 Restore operations
4 Format floppy disks
Your choice [1..4, Q] ? 1
ALCATEL-LUCENT
Immediate backup on cpu disk Installation FACILITIES 2.67.0
Space used on cpu disk: 3%
1 Backup mao, voice guides and accounting data
2 Backup mao data
3 Backup accounting data
4 Backup voice guides
5 Backup mao data for rebuild
6 Backup traffic history
7 Backup Acd config & statistic files
8 Backup 4645 data
9 Backup 4645 data without messages
10 Backup 4635 data
11 Backup Linux (Unix) site specific data
Your choices [1..11, Q] ?
One choice per line and just press "return" to end the selection
Your choice ==>
ogunkua
Post by ogunkua »
Thank you all. I appreciate your efforts.
