Rescue Image "nrescue.img"
pascalxsome
Post by pascalxsome »
Hello to all of you,
while playing around with a OS6560-P48Z16, i messed up and are in need of the nrescue.img file, to create a USB-Rescue device.
Anyone has an idea where to download it? Couldn't find it in any earlier release I've downloaded so far.
Alu4u-Wiki, as often mentioned, sadly does not provide any image for this switch.
Thank you so much in Advance,
Pascal
Re: Rescue Image "nrescue.img"
You need to open a SR for it. But I have done this some time ago. See the attachement.
BR Silvio
ntripier
Post by ntripier »
Can you give me the detailed procedure to recover a 6560 switch?
Thank you
Same at all switches - but now with folder 6560
https://www.alcatelunleashed.com/viewto ... ry#p113151
stick with the rescue-fie in the root and /6560/certified/Nos.img
denipotte
Post by denipotte »
Someone, have 6860E-P24 image?
thermseeker
Post by thermseeker »
I just opened a box with a brand new OS6360-P48 and it went straight into asking me to run rescue... The switch is under warranty but I'd like to avoid going through the RMA process, even because I need the switch right now and not in a few weeks. It's asking for a different file, Narescue.img. Any idea where to get it? At the same time I'll ask the vendor.
Tales
you find it in myportal at the software part for the switches.
It is not allowed to share the image files here anymore.
best regards
Return to “OmniSwitch 6560”
