Factory rest
Abdallah
Factory rest
Post by Abdallah »
What is the CLI to make Factory rest to OS6465-p12?
Abdallah
Re: Factory rest
delete the boot.cfg within the working and certified directory. Also you can delete all files direct within the flash-directory (f.e. boot.slot.cfg and swlog) and in the network folder (f.e. usertable.).
diagne21
Re: Factory rest
Post by diagne21 »
I deleted the NOS.img file from my 6-port 6465 switch and I can't start it anymore thanks for your support
cordially
Re: Factory rest
within the working and certified you should only delete the config-files = *.cfg (R6 switches: boot.cfg, R8-switches: vcsetup.cfg and vcboot.cfg). The Image-files (*.img) are necessary. But you can delete all other files within the switch.
diagne21
Re: Factory rest
Post by diagne21 »
Hello silvio,
I would like to know how to put the NOS.img file back.
Where I can download it.
Thank you
cordially
Re: Factory rest
You need access to the business portal (for ALE partners only), or you ask the supplier of the switches (he should help you) or you can copy the file from an other OS6465 (via ftp, scp or USB).
BR Silvio
Fr_Luc
Re: Factory rest
Post by Fr_Luc »
Hello
I have the same problem.
I delete my Nos.img in the directory "working" and "certified" but i have a copy in a other directory "running".
I want to copy/move this file in the great directory.
But i can't do it with the Mini-boot Marvell.
I search the command.
Listen of the command help:
Marvell>> help
? - alias for 'help'
Creset - Creset - Run 'reset' or boot command in a loop, while counting.
SatR - Sample At Reset sub-system
active_units- print active units on board
allowRootAccess- allowRootAccess - Allow AOS access as root
base - print or set address offset
bdinfo - print Board Info structure
boot - boot default, i.e., run 'bootcmd'
bootd - boot default, i.e., run 'bootcmd'
bootelf - Boot from an ELF image in memory
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
bootvx - Boot vxWorks from an ELF image
bootz - boot Linux zImage image from memory
bubt - bubt - Burn an image on the Boot flash device.
chpart - change active partition
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
cpss_env- set cpss environment variables permanently
crc32 - checksum calculation
ddrPhyRead- ddrPhyRead - Read DDR PHY register
ddrPhyWrite- ddrPhyWrite - Write DDR PHY register
dhcp - boot image via network using DHCP/TFTP protocol
diskboot- diskboot- boot from IDE device
dma - dma - Perform DMA using the XOR engine
echo - echo args to console
editenv - edit environment variable
eeprom - EEPROM sub-system
env - environment handling commands
exit - exit script
ext2load- load binary file from a Ext2 filesystem
ext2ls - list files in a directory (default /)
ext4load- load binary file from a Ext4 filesystem
ext4ls - list files in a directory (default /)
ext4write- create a file in the root directory
false - do nothing, unsuccessfully
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls - list files in a directory (default /)
fdt - flattened device tree utility commands
flash_part_print- flash_part_print - print spi/nand FLASH memory information
fpga_refresh- fpga_refresh - reload FPGA code
fsinfo - print information about filesystems
fsload - load binary file from a filesystem image
go - start application at address 'addr'
help - print command description/usage
i2c - I2C sub-system
ide - ide - IDE sub-system
iminfo - print header information for application image
imxtract- extract a part of a multi-image
ir - ir - reading and changing MV internal register values.
itest - return true/false on integer compare
loadb - load binary file over serial line (kermit mode)
loads - load S-Record file over serial line
loadx - load binary file over serial line (xmodem mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
map - map - Display address decode windows
md - memory display
me - me - PCIe master enable
mm - memory modify (auto-incrementing address)
mmc - MMC sub system
mmcinfo - display MMC info
mp - mp - map PCIe BAR
mtdburn - Burn a Linux image and Filesystem` on the NAND/SPI flash.
mtdparts- define flash/nand partitions
mtest - simple RAM read/write test
mvsource- mvsource - Burn a script image on flash device.
mw - memory write (fill)
nand - NAND sub-system
nboot - boot from NAND device
nm - memory modify (constant address)
pci - list and access PCI Configuration Space
pciePhyRead- phyRead - Read PCI-E Phy register
pciePhyWrite- pciePhyWrite - Write PCI-E Phy register
phyRead - phyRead - Read Phy register
phyWrite- phyWrite - Write Phy register
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
pxe - commands to get and boot from pxe files
qsgmii_sel- Select SFP or QSGMII modes on bc2.
rcvr - rcvr - Start recovery process (with TFTP server)
reset - Perform RESET of the CPU
resetenv- resetenv - Erase environment sector to reset all variables to default.
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
scsi - SCSI sub-system
scsiboot- boot from SCSI device
se - se - PCIe Slave enable
setAdminPasswordDefault- setAdminPasswordDefault - Reset AOS admin user password to default
setenv - set environment variables
sf - SPI flash sub-system
sg - sg - scanning the PHYs status
showvar - print local hushshell variables
sleep - delay execution for some time
smiscan - smiscan - Scan for marvell smi devices.
source - run script from memory
sp - scan and detect all devices on PCI-e interface
sspi - SPI utility command
switchRegRead- switchRegRead - Read switch register, using Address completion
switchRegWrite- switchRegWrite - Write to switch register, using Address completion
sysboot - command to get and boot from syslinux files
temp - temp - Display the device temperature.
tempCmd0- tempCmd - This command allocated for monitor extinction
tempCmd1- tempCmd - This command allocated for monitor extinction
tempCmd2- tempCmd - This command allocated for monitor extinction
tempCmd3- tempCmd - This command allocated for monitor extinction
test - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
training- training - prints the results of the DDR3 Training.
trainingStability- training - prints the results of the DDR3 Training.
true - do nothing, successfully
ts_report- ts_report - report touch screen coordinate
ts_test - ts_test - test touch screen
ubi - ubi commands
ubifsload- load file from an UBIFS filesystem
ubifsls - list files in a directory
ubifsmount- mount UBIFS volume
ubifsumount- unmount UBIFS volume
usb - USB sub-system
usbboot - boot from USB device
version - print monitor, compiler and linker version
whoAmI - - reading CPU ID
Or maybe they are another solution with a USB key ?
Fr_Luc
Re: Factory rest
Post by Fr_Luc »
Ok i find a solution.
We need to have an other switch 6465 and copy "certified" and "working" in a USB key.
You can get the Nrescue file in an other topic.
When your USB key is good. Put him in your switch.
Turn on, when you see "Marvell>>"
write "run rescue"
Yes for the first question and No after.
When you switch is rebooted
write"boot"
Re: Factory rest
thanks for find the correct solution by yourself.
Meantime I have checked if there is another way to copy files within the boot menu. But I didn't find any possible command. So the disaster recovery (like written very often here in the forum) is the onliest way.
mmankollari
Re: Factory rest
Post by mmankollari »
I wanted to ask if there is any link to download the Nrescue.img file for the OmniSwitch 6465.
My switch keeps rebooting and I can't find this file anywhere so I can reset it by using "run rescue" command.
Thank you in advance!
Return to “OmniSwitch 6465”
