Hello again,
just to document everything here in case others are finding this forum with similar questions.
Firstly, of course, there was the challenge of getting into the serial console – the problem of the missing cable seems to be pretty universal (and honestly, I pretty much question the wisdom of the manufacturer to use a proprietory connector in this case). Worse yet, there seem to be multiple different wirings documented, so it was a bit of guesswork to find the right one.
My solution was a combination of a USB-to-Serial adapter, a serial terminal-block adapter and an old Ethernet cable that had one side broken anyways. Here's how that looks like (a bit hotch-potch, I know, but it works
I wired it as follows:
Serial/terminal - RJ45 connector
1 —
2 — 6
3 — 3
4 — 2
5 — 4
6 — 7
7 — 1
8 — 8
9 —
I used PuTTY with the usual serial port settings (9600 baud, 8/1 bits, no parity, XON/XOFF) and got greeted with what seemed an endless list of boot messages. Success!
When prompted I logged in with the default user name ("admin") and password ("switch") and hooray!
The following was all from the "OmniSwitch 6400 Series Getting Started Guide". I just repeat it here because it is already difficult to find this document and this here may stay online for longer...
Firstly, give that switch an IP address, so I can log in via telnet or via the web interface rather than that pesky serial cable...
ip interface my_vlan address 192.168.1.10 vlan 1
Secondly, activate remote access services on the switch; Simply all of them, I can remove the unneeded ones later:
High time to set a new, more secure password:
After setting a new password, I was asked to re-authenticate but the console accepted neither the new nor the old password at first. Strange ... I could however log in via the web interface and that accepted the new password. Also, when I connected again to serial a few minutes later, I could in fact log in with the new passport, so that seems to be a little glitchy. Doesn't matter, it's not something I'll do very often...
I changed all the other settings (time zone, date, location, etc.) in the web interface. Much easier than typing commands...
À propos date: I couldn't find a setting for configuring an NTP server... did I miss something?
In any case, it seems to work. Cool!
