OmniSwitch 6865 spantree blocking
mikeamores
Post by mikeamores »
hi,
how to prevent spantree looping and blocking the vlan. i have OmniSwitch 6865 setup Primary and Slave ( VC chassis Auto ) with Static Linkaggregation to all OmniSwitch6350 . I have an issue, when i enable the interfaces on the Slave interfaces the VLANs blocking. when you ping to the ip address is destination host unreachable sometimes can ping 3times, Any configuration can recommend. Thank you for your help.
Re: OmniSwitch 6865 spantree blocking
if ports within the linkagg are blocked than you haven't created the linkagg correctly. Better choice is lacp instead of static.
Otherwise there are a lot of reasons for this behavior - especially loops, wrong stp setting (mode is different).
mikeamores
i triy lacp configuration, existing configuration are static, is this the best way to resolve the issue. thanks for reply.
Return to “OmniSwitch 6865”
