Bandwidth / throughput
tpkennes
Post by tpkennes »
Dear expert,
How do you check how much throughput is going through a lag or a port ?
Something similar as we have on Cisco routers :
sh int gi0/10
GigabitEthernet0/10 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is xxxxxxxx
Description: "Test interco "
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
ARP type: ARPA, ARP Timeout 04:00:00
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
1529072 packets input, 106044286 bytes, 0 no buffer
Received 8 broadcasts (0 multicasts)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
0 input packets with dribble condition detected
63087227 packets output, 4420395109 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 pause output
0 output buffer failures, 0 output buffers swapped out
Thanks,
lo0
Re: Bandwidth / throughput
Post by lo0 »
monitor [ port | lag ] [ <port-id> | <lag-id> ] [ absolute | rate ] interval <seconds> repeat <repeat>
Return to “7210 SAS”
