Loopback0 problem
Alcanoob123
Loopback0 problem
Post by Alcanoob123 »
I am having a problem configuring the Loopback0 address on the OS6465. I am using the 6465 as a replacement for the 6250 that is no longer being made. In the 6250, I would configure a mgmt address on /32, vlan 2816, and then the Loopback0 address would be given the same ip. The 6465 no longer allows this. Please see example below:
6250:
ip interface mgnt_vlan address 10.28.16.2 mask 255.255.255.240 vlan 2816
ip interface Loopback0 address 10.28.16.2
ip static-route 0.0.0.0 mask 0.0.0.0 gateway 10.28.16.1 metric 1
6465:
+++ address for Loopback0 (10.28.16.2/255.255.255.255) conflicts with address for mgnt_vlan (10.28.16.2/255.255.255.240)
ERROR: Ip Address must not conflict with interface mgnt_vlan
My apologies, I am brand new to this site, and as you can see, new to networking.
Re: Loopback0 problem
In your case loopback0 is not necessary to configure. You need only the both other lines.
Return to “OmniSwitch 6465”
