I have to modify the company's phone book
without changing name and other setting,
i.e only extension number has to be changed.
even names won't be changed.
"i am using omnivista 4760"
Phone book modification
knightr1der
Re: Phone book modification
can you be more specific please.
Please give an example of a user with old settings and what the new settings should be.
athos19
by extension number
i mean directory numbers
for all user (only directory numbers)
export everything, modify on excel or similar, erase all from OXE and reimport
athos19
do i need to delete all, what if i just reimport
the text or excel file after modification.
i am afraid of the erase thing
athos19
do i need to delete all ??
If you import without delete will be like adding new users...
athos19
what about physical
settings ?? for each directory number i.e
location node,
shelf address,
board address
what about physical
location node,
shelf address,
board address
