Fan Not Running
vappleyard
Fan Not Running
Post by vappleyard »
Hi people!
I have an OmniSwitch 6350.
When I checked the FAN status FAN1 show as "Not Running"
show fan
Chassis Fan Status
1 1 Not Running
1 2 Running
1 3 Running
1 4 Running
This message can be considered as a FAN Faliure or is a normal condition for FAN?
Thanks in advance!
Re: Fan Not Running
it is normal behavior. if the temperatur is higher than other fans will run too.
Fan failure you will see in the swlog.
vappleyard
Re: Fan Not Running
Thank you!
surajkants
Re: Fan Not Running
Post by surajkants »
I have 6450-p24
show fan
Chassis Fan Status
1 1 Running
1 2 Running
1 3 Running
Q: In console all three fan showing running while physically I checked single fan is running,
Can I conclude that something is wrong with switch.
Re: Fan Not Running
no. Sometimes (depending from hardware and software) the fans are running slower - sometimes a part of the fans are down. If there is no error message and the temperature is normal than all is okay.
Return to “OmniSwitch 6350”
