Backstory: recently, my CS board died. The seller replaced it but the system started to report unactivated every time I used the console, also it was reporting "Wrong CPU-ID". They said the message would go away as soon they change the licence within Alcatel, which they said they did.
Some time passed, the Wrong CPU-ID message is still on. Also, there are two CPU-IDs - the ID 0, which is the same as the board installed, and the ID 1, a very long ID that starts with "CCSID" and I can't delete it, the system says there is no CPU-ID 01.
Now, things got worse. Every phone here is saying "Call Installer". The message goes away for some hour every time I reload the OPS files.
I checked the settings, and this forum, did what I could, but I couldn't figure out how to fix this error:
ooo Reading string-file /DHS3bin/oneshot/mtcl/objects.US0 ...
ooo Reading string-file /DHS3bin/oneshot/mtcl/spadmin.dct ...
ooo Reading string-file /DHS3bin/oneshot/mtcl/err2lov.dct ...
Display current counters ........................... 1
Display active file ................................ 2
Check active file coherency ........................ 3
Install a new file ................................. 4
Read the system CPUID .............................. 5
CPU-Ids management ................................. 6
Display active and new file ........................ 7
Display OPS limits ................................. 8
Display ACK code ................................... 9
Exit ............................................... 0
choice : 3
[b]> Checking active file /DHS3data/mao/software.mao
Error: Illegal hardware key[/b]
Thank you.
