OXE resetting
Re: OXE resetting
That is what happens when you have cls and ground reversed - if you open the terminal emulator while connected to the oxe/gd it will reset - check your cable
- cavagnaro
Re: OXE resetting
Well considering i was no more than 12 years old when the saw the program the fact i remember some importants stuff about it is good enought, however as you were oldie you must remember more things than meknightr1der wrote:do monkeys really have short memories? KITT was nuclear powered and not battery powered. Still, I suppose nuclear power is even more dangerous in the hands of a primatecavagnaro wrote:Don't know, but wonder what can happen to you if i invert the battery cables you have
Re: OXE resetting
Thank you for your help.
Now i want to change the mtcl Passwort. But putty and hyperterminal told me root "login refused on this terminal" What can i do?
