Built-in Phonebook in OXO Connect
Chase West
Post by Chase West »
Does OXO Connect has built-in phonebook feature that can use by deskphones without needing to connect to external directory source like ldap or ftp?
My first time to deploy OXO Connect w/ 200pcs of 8001 sip phones. Is it possible to see the name list list of extensions on the phonebook of 8001 deskphones?
Again, the OXO without connecting to ldap.
Thanks.
rkraehen
Re: Built-in Phonebook in OXO Connect
Post by rkraehen »
Yes, in the system limits you can check how many Collective Speed Dial entrees are available (up to 2200). The 8001 has a local directory only. You would need an 8008 to see the names of the Collective Speed Dial.
