Door Opener on OmniPCX OXO
aserranog
Post by aserranog »
Hi to all,
Is it possible to connect the OminiPCX to a Door Opener but does not have a door phone?
Our door hat only the opener and a button to open it.
Thanks in Advance!
Re: Door Opener on OmniPCX OXO
Yes, it is possible if you use a relay.
You would need to change the door lock though obviously.
aserranog
Post by aserranog »
Hi Frank,
Thank you for your tip! The problem was that it did not have the AFU card.
The history of our PABX is as follows. This was acquired 10 years ago for rent. The partner that managed this service closed two or three years ago. I'm heer for a year and having knowledge of PABX, I am taking charge of its maintenance. I discovered that many articles that were in the contract are not installed (AFU, HDD, Antennas ...). In summary ... a chaos.
Best Regars!!
