Help modify Vlan 1 to an other ID
plegrand
Post by plegrand »
Hello, i have to modify all my switches configuration to pass from vlan 1 to an other ID
actually my configuration on old LS 6224p is like that :
vlan database
vlan 2-3,99
exit
interface range ethernet g(1-2)
switchport trunk allowed vlan add 2
exit
switchport trunk allowed vlan add 3
exit
interface range ethernet e(1-7)
switchport trunk native vlan 3
exit
interface range ethernet e(1-24),g(1-2)
switchport trunk allowed vlan add 99
exit
Is it the same configuration as the following ?
vlan database                        |
vlan 1                               |
exit                                 |
vlan database
vlan 2-3,99
exit
interface range ethernet g(1-2)      |
switchport trunk native vlan 1       |
exit                                 |
exit
exit
exit
interface range ethernet e(8-24)
exit
exit
Then to plan my modification does these commands are OK ?
On OS 6250
->vlan 1 enable name "Enseignants-OLD"
->vlan 4 enable name "Enseignants"
->show vlan 1 port
->vlan 4 port default ..... all ports from the result of the previous command
On LS 6224p
#vlan database
#vlan 4
#exit
#interface vlan 1
#name Enseignants-OLD
#exit
#interface vlan 4
#name Enseignants
#exit
#show vlan tag 1
Vlan       Name                   Ports                Type     Authorization
 1           1           e(8-24),g(1-2),ch(1-8)       other       Required
From the result of the previous command :
#interface range ethernet g(1-2)
#switchport trunk native vlan 4
#exit
#interface range ethernet e(8-24)
#exit
Thanks for your help
Re: Help modify Vlan 1 to an other ID
Hi ,
just run a "show configuration snapshot". Save the file, edit it, change it, re-upload the file in your OmniSwitches, and check if it works the way you want.
Return to “OmniStack LS 6200”
