This document will show you how to run traces and record a VoIP conversation of a serie 8 phone, by using its own PC-LAN port.
Enjoy !
How to trace a VoIP on a Serie 8 phone, using its LAN port
- frank
Re: How to trace a VoIP on a Serie 8 phone, using its LAN port
very useful
thank you mate!
thank you mate!
with new releaseof wireshark you have already alcatel prptocols -ua3g-uaupd etc ..
thanks for the post very useful
Hi why I can not use this command ?
NoePhone > mirror set lan
mirror set lan
#mirror#
pc port protection on, mirror deactivated
mirror KO
thanks
mirror set lan
#mirror#
mirror KO
thanks
ACFE R10.0
mokhtar.belkhiati@gmail.com
- tot3nkopf
On your 8&9 phone set cos the lan port is deactivated.
Assign different cos with lan port activated, reboot the phone, use the command.
