Hi! - I moved the server over the week end to handle the daily incoming connections (about 200K/day) but it looks like I aimed too low for the resources. I'm going to have to move this server (hopefully for the last time) this week. I'm sorry for the interruption.
Misleading error message when create profiled subscriber fails: the server is not yet available
ssteiner
Post by ssteiner »
My whole license odyssey started with this issue last week (that is now back that the license issue is sorted).
I'm creating UA virtual sets using the profiled subscriber functionality. That used to work until a week ago. Now I'm getting this
	"httpStatus": "SERVICE_UNAVAILABLE",
	"code": 1000,
	"helpMessage": "The server is not yet available. Please retry later if the initialization is not finished.",
	"type": "NOT_READY",
	"innerMessage": "Connection failed",
	"canRetry": true
Not very helpful I'd dare say. Especially given that other such operations work just fine (e.g. when I create IPTouch devices).
The request being
	"attributes": [{
		"name": "Station_Type",
		"value": ["UA_VIRTUAL"]
		"name": "Entity_Number",
		"value": ["18"]
		"name": "Directory_Number",
		"value": ["1011"]
		"name": "Station_Profil_From",
		"value": ["A43010"]
		"name": "Keys_Profil_From",
		"value": ["A43010"]
		"name": "Phone_Book_First_Name",
		"value": [null]
		"name": "Phone_Book_Name",
		"value": ["ssteteam2"]
		"name": "Equipment_Address.Equipment_Address_Rack",
		"value": ["255"]
		"name": "Equipment_Address.Equipment_Address_Board",
		"value": ["255"]
		"name": "Equipment_Address.Equipment_Address_Terminal",
		"value": ["255"]
Turns out (now that I'm looking at it before posting)... Phone_Book_First_Name = null is not something O2G likes. If I put an empty string there, things are back to normal.
I think the behavior should be changed.. this message is highly misleading.
yblanchard
Re: Misleading error message when create profiled subscriber fails: the server is not yet available
Post by yblanchard »
the error comes from the null value of a string attribute.
=> the wrong error will be replaced by a clear error message ""value 'null' is not allowed for attribute ..."
ssteiner
Post by ssteiner »
in which version should I look for this behavior change?
yblanchard
in build 29.
For a string attribute, the message "value null is not allowed for attribute xxx" is returned if the attribute is present, and the string value contains [] or [null]: this control is done at O2G level.
To set an empty value: use [""], like with mgr.
For some objects, It is also possible to not send the attribute, if it is allowed by OXE
Return to “O2G”
