Hi @all,
we have to connect some other pbx via SIP-Trunk with the oxe R12, but all 15 network routing tables are used!
any idea how to solve this issue?
network routing tables all used
Re: network routing tables all used
you can find choice network routing table at Remote network : ... of trunk group.
Try with cfgUpdate (up to 255 networks).
Dear All
Can I user Prefix plan *201 to use routing Number Instead of Discriminator number ? In the routing number im add TG and SipExtgw associated
Eko
Eko
