Alcatel Lucent OmniStack LS 6224 switch console port does'nt work
JuanP
Post by JuanP »
Hello everyone,
My objective with this switch is to reset it to default.
As the subject tells i have an Alcatel Lucent Omnistack Ls 6224 Switch that can't be access via console port, i tried many times using the manual trying differents speeds and none work.
So i was wondering if there is a way to reset it via hardware like using a jumper.
This is the manual i found: https://www.manualslib.com/manual/35642 ... e=4#manual
Thankyou in advance for your time.
mdhussainvlr
Re: Alcatel Lucent OmniStack LS 6224 switch console port does'nt work
Post by mdhussainvlr »
Have you tried your console with other switch and see your console works
