Alcatel OmniStack LS 6224 switch console port does'nt work
JuanP
Post by JuanP »
Hello everyone,
I have an Alcatel Omnistack LS 6224 switch, wich i can't access via console to establish factory default, so i was wondering if anyone knows if there is a way to factory reset on the hardware itself, like via jumpers or somehow. I had been reading the manual looking for someway to establish factory default but i can't find anything that can help me.
https://www.manualslib.com/manual/35642 ... e=4#manual
Thankyou in advance for your time.
Re: Alcatel OmniStack LS 6224 switch console port does'nt work
no - only via serial.
JuanP
Post by JuanP »
thank you very much. i really appreciate your reply.
Return to “OmniStack LS 6200”
