I have the 8038 noe phone, and i need to convert it to SIP for configure with Asterisk.
I turned off the phone, then at the power on i press "123i" button since the string "connected" appear on screen.
After i connect to it 192.168.199.1 by telnet console and execute the command "appl mode SIP", and the phone start to search the file:
noesip8038N
datsip8038N-header
datsip8038N
to TFTP server.
Does any of you have the SIP Binary files for conversion and provisioning(standard)?
Is the correct procedure?
Thank's
Carlo
[NOEtoSIP] Alcatel-Lucent 8038 - procedure
carlocarlo
Re: [NOEtoSIP] Alcatel-Lucent 8038 - procedure
Usually - binary files present on OXE (/usr2/downbin folder).
What you use as tftp server?
carlocarlo
thank's for reply, for test i user Tftp64.
I try to look on the company's OXE server, hoping they will give me access.
Is it correct procedure?
carlocarlo
for the production i use "tftp-hpa 0.49" or "tftp-hpa 5.2".
kamel27hk
Did you find a solution or not yet?
Because I can help you.
I just make it happen
rafeaa
Hello, thank you. I have the same problem help me please
