Dear all,
I have an OXE 8.0.1 system.
I tried to install a new trunk in my system. (Trunk group 99)
When I choose direct seizure of the trunk, works correctly, the station can use the trunk.
In discriminator I set the new instance
+-Consult/Modify: Discriminator Rule-----------------------------------------------------------------+
| Node Number (reserved) : 1 |
| Instance (reserved) : 1 |
| Discriminator Nr. : 0 |
| Call Number : 21 |
| Area Number : 2 |
| ARS Route List Number : 99 |
| Schedule Number : -1 |
| Number of Digits : 3 |
When I try to call, I get a "you can not use" error message.
The area can be called.
What I missed, or how can I debug it?
ARS - Route - Permission
Re: ARS - Route - Permission
+-Consult/Modify: Users--------------------------------------------------------------------+
| Directory Number : 206 |
| Directory name : 206 |
| Directory First Name : -------------------- |
| UTF-8 Directory Name : ------------------------------------------- |
| UTF-8 Directory First Name : ------------------------------------------- |
| Location Node : 1 |
| Shelf Address : 255 |
| Board Address : 255 |
| Equipment Address : 255 |
| Set Type + IPTouch 4028 |
| Entity Number : 1 |
| Set Function + Default |
| Profile Name : --------------- |
| Key Profile + None |
| Identifier of Domain : 0 |
| Language Id. : 1 |
| Secret Code : **** |
| Confirm : **** |
| Associated Set No. : 206 |
| Cost Center Id : 255 |
| Cost Center Name : ---------- |
| Charging Category + Justified |
| Public Network Category : 2 |
| External Forwarding Category : 255 |
| Tel.Facility Category Id : 0 |
| Connection Category Id : 0 |
| Hunting Group Dir No. : -------- |
| ACD Group Directory No. : -------- |
| Pick up Group Name : ---------------- |
| Reserved Time Slot + False |
| Voice Mail Dir.No. : -------- |
| Voice Mail Type + No Voice Mail |
| Paging Trunk Group : 255 |
| Paging Beeper : ---- |
| Tele-Marketing Agent + False |
From this I need this lines:
Entity Number : 1
That's ok?
Entity 1:
+-Consult/Modify: Entities------------------------------------------------------------------------------+
| Entity Number : 1 |
| Name : Alap entitas |
| UTF-8 Name : --------------------------------------------------------------- |
| Attendant Group Manager : 0 |
| Priority + NO |
| Trafic Overflow + Disallowed |
| Installation No (ISDN) : ------------------------------ |
| Supplement.Install.No (ISDN) : ------------------------------ |
| Caller Id.Secret + No |
| Adv.Of Charg.2 requests(AOC2) + NO |
| Adv.Of Charg.3 requests(A0C3) + NO |
| Auto. Locking : 0 |
| Voice Mail Box No.for attendt : -------- |
| Trunk Group Id : -1 |
| Calls Distribution |
| Overflow Routing No. : -------- |
| Forwarding on routing + NO |
| 1st Night Routing : -------- |
| 2nd Night Routing : -------- |
| 3nd Night Routing : -------- |
| 1st Day Routing : -------- |
| 2nd Day Routing : -------- |
| 3nd Day Routing : -------- |
| 1st MODE 1 Routing : -------- |
| 2nd MODE 1 Routing : -------- |
| 3nd MODE 1 Routing : -------- |
| 1st MODE 2 Routing : -------- |
| 2nd MODE 2 Routing : -------- |
| 3nd MODE 2 Routing : -------- |
| Calls Priority |
| Normal Public Trk grp Ent. : 6 |
| Urgent Public Trk grp Ent. : 5 |
| Normal Private trk grp Ent. : 10 |
| Urgent Private Trk grp Ent. : 9 |
| Normal Public DDI Entity : 6 |
| Urgent Public DDI Entity : 5 |
| Normal Private DDI Entity : 10 |
| Urgent Private DDI Entity : 9 |
| Normal Int Callee DDI Entity : 12 |
| Urgent Int Callee DDI Entity : 11 |
| Normal Public Non Answer DDI : 4 |
| Urgent Public Non Answer DDI : 3 |
| Normal Private Non Answer DDI : 8 |
| Urgent Private Non Answer DDI : 9 |
From this I need:
Thats's ok?
Phone facility 0
| Abbreviated Dialling Area |
| Area 0 : 1 |
| Area 1 : 1 |
| Area 2 : 1 |
| Area 3 : 1 |
| Area 4 : 1 |
| Area 5 : 1 |
| Area 6 : 1 |
| Area 7 : 1 |
| Area 8 : 1 |
| Area 9 : 1 |
| Area 10 : 1 |
| Area 11 : 1 |
| Area 12 : 1 |
| Area 13 : 1 |
| Area 14 : 1 |
| Area 15 : 1 |
| Area 16 : 1 |
| Area 17 : 1 |
| Area 18 : 1 |
| Area 19 : 1 |
| Area 20 : 1 |
| Area 21 : 1 |
| Area 22 : 1 |
| Area 23 : 1 |
| Area 24 : 1 |
| Area 25 : 1 |
| Area 26 : 1 |
| Area 27 : 1 |
| Area 28 : 1 |
| Area 29 : 1 |
| Area 30 : 1 |
| Area 31 : 1 |
In Public network category:
+-Consult/Modify: Public Access Category-------------------------------------+
| Area Identifier : 2 |
| Public Access Rights |
| Night : 1 |
| Day : 1 |
| Mode 1 : 1 |
| Mode 2 : 1 |
Prefix plan:
+-Consult/Modify: Prefix Plan---------------------------------------------+
| Number : 0 |
| Prefix Meaning + ARS Prof.Trg Grp Seiz.with overlap |
From this, I need Discriminator logical 0
From Entity's discriminator:
+-Consult/Modify: Discriminator Selector-------------+
| Entity Number : 1 |
| Discriminator 00 : 0 |
| Discriminator 01 : 1 |
| Discriminator 02 : 0 |
| Discriminator 03 : 0 |
| Discriminator 04 : 0 |
| Discriminator 05 : 0 |
| Discriminator 06 : 0 |
| Discriminator 07 : 0 |
I get the 0 physical Discriminator
+-Consult/Modify: Numbering Discriminator----------------------------------------+
In discriminator I set the entry:
| Call Number : 21 |
| Area Number : 2 |
ARS route list 99:
+-Consult/Modify: ARS Route list-------------------------+
| ARS Route list : 99 |
It contains one entry:
+-Consult/Modify: ARS Route--------------------------------------------------+
| Route : 1 |
| Name : Analog trunk |
| Trunk Group Source + Route |
| Trunk Group : 99 |
| Nb.Digits To Be Removed : 0 |
| Digits To Add : ------------------------------ |
| Numbering Command Tabl.Id : 0 |
| VPN Cost Limit : 0 |
| Protocol Type + Dependant on Bundle Type |
| NPD identifier : 34 |
| Route Type + Public |
| ATM Address Id : -1 |
| Preempter + False |
| Quality |
| [ Add ] [ Remove ] [ Next ] [Previous] |
| Quality + Speech |
+-Consult/Modify: Trunk Groups------------------------------------------------------+
| Trunk Group Id : 99 |
| Trunk Group Type + NDDI (BCA) |
| Trunk Group Name : BP250 |
| UTF-8 Trunk Group Name : BP250 |
| Number Compatible With : 0 |
| Remote Network : 15 |
| Shared Trunk Group + False |
| Special Services + Nothing |
| Node number : 1 |
| Transcom Trunk Group + False |
| Auto.reserv.by Attendant + False |
| Overflow trunk group No. : -1 |
| Tone on seizure + True |
| Private Trunk Group + False |
| Paging Trunk Group + False |
| Paging Table Id : -1 |
| Paging Signalization + NDDI |
| Security Patrol + False |
| Prefix Sending + False |
| auto.DTMF dialing on outgoing call + NO |
| DDI transcoding + False |
| Register Signalling + Decadic/MF Q23 |
| Implicit Priority |
| Activation mode : 0 |
| Priority Level : 0 |
| Preempter + NO |
| Incoming calls Restriction categ. : 10 |
| Outgoing calls Restriction categ. : 10 |
+-Consult/Modify: Trunk Group------------------------------+
| Public Network Ref. : ------ |
| VG for non-existent No. + YES |
| Entity Number : 0 |
| Supervised by Routing + NO |
| VPN Cost Limit for Incom.Calls : 0 |
| Immediat Trk Listening For VPNCall + YES |
| VPN TS % : 50 |
| Csta Monitored + NO |
| Max.% of trunks out CCD : 0 |
| Ratio analog.to ISDN tax : ------ |
| TS Distribution on Accesses + YES |
| Quality Profile for Voice on IP + Profile #1 |
| IP compression type + Default |
| Use of volume in system + YES |
| Announcement for Dialtone + NO |
| Announcement for Ringtone + NO |
| Private to Public Overflow + YES |
| Dialling end to end + NO |
| DTMF end to end signal. + NO |
| Paying Incoming Calls + NO |
| TS Permanently assigned + YES |
| Min. Nb.of digits on seize : 0 |
| Trunk group used in DISA + NO |
| DISA Secret Code : ---- |
| Routing To Executive + NO |
| Dissuasion For ACD + NO |
| DTO joining + NO |
| Automated Attendant + NO |
| Calling party Rights category : 0 |
| Access Cluster Id : -1 |
| Collect Calls Allowed + YES |
+-Consult/Modify: Trunk----------------------------------+
| Physical Address : 3-6-6 |
| Trunk Category Id : 3 |
| Directory Name : -------- |
| Trunk Routing Number : 206 |
| Channel Specialization + Mixed |
| Trunk Number : 68 |
| Data Transparency + NO |
So.
What I missed?
| Location Node : 1 |
| Entity Number : 1 |
| Language Id. : 1 |
| Confirm : **** |
Entity Number : 1
That's ok?
Entity 1:
| Entity Number : 1 |
| Priority + NO |
| Auto. Locking : 0 |
| Calls Priority |
From this I need:
Thats's ok?
Phone facility 0
| Area 0 : 1 |
| Area 1 : 1 |
| Area 2 : 1 |
| Area 3 : 1 |
| Area 4 : 1 |
| Area 5 : 1 |
| Area 6 : 1 |
| Area 7 : 1 |
| Area 8 : 1 |
| Area 9 : 1 |
| Area 10 : 1 |
| Area 11 : 1 |
| Area 12 : 1 |
| Area 13 : 1 |
| Area 14 : 1 |
| Area 15 : 1 |
| Area 16 : 1 |
| Area 17 : 1 |
| Area 18 : 1 |
| Area 19 : 1 |
| Area 20 : 1 |
| Area 21 : 1 |
| Area 22 : 1 |
| Area 23 : 1 |
| Area 24 : 1 |
| Area 25 : 1 |
| Area 26 : 1 |
| Area 27 : 1 |
| Area 28 : 1 |
| Area 29 : 1 |
| Area 30 : 1 |
| Area 31 : 1 |
| Night : 1 |
| Day : 1 |
| Mode 1 : 1 |
| Mode 2 : 1 |
Prefix plan:
| Number : 0 |
| Entity Number : 1 |
| Call Number : 21 |
| Area Number : 2 |
ARS route list 99:
| Route : 1 |
| Trunk Group : 99 |
| Preempter + False |
| Quality |
| Quality + Speech |
| Node number : 1 |
| Implicit Priority |
| Preempter + NO |
| Entity Number : 0 |
| VPN TS % : 50 |
| DTO joining + NO |
| Trunk Number : 68 |
So.
What I missed?
I found the problem:
With "lookars i", I found the difference.
The ARS0 has a Time Based Route List; When I created, it works!
+-Consult/Modify: Time Based Route List--------------------------------------+
| ARS Route list : 0 |
| Time Based Route List Id : 1 |
| Time Based Route |
| Time Based Route |
| Route Number : 1 |
| Waiting Cost Limit : -1 |
| Stopping Cost Limit : -1 |
| Time Based Route |
| Time Based Route |
| Route Number : 1 |
Time based route list - the main problem for basic setup, two error:
- time based route list not created,
- when exist two routes - created two time based route lists (with route 1 and route 2) instead of one time based route list with two routes.
Another problem (for ISDN TG) - when declared Quality=Speech (only). (I suggest declare Speech and Fax)
Thanks!
Always need a time based route list?
This is now an analog line, but I wrote a notice for me about ISDN!
Thanks.
Thanks.
Time based route list must exist.
HI as Vad told to you no ARS working without time based route list under the ars route list also
to check
user COS area and tkg are authorised
Welcome to pst_cpu6
Alcatel-Lucent OmniPCX Enterprise
login: mtcl
Password:
standard installation last performed: 17-Jan-2016 13:06:47
# The role of the CPU is MAIN
Application software identity
R9.1-i1.605-41-dz-c7s2
Business identification: R9.1
Release:
DELIVERY i1.605
Patch identification: 41
Dynamic patch identification: none
Country: dz
Cpu: c7s2
ACD VERSION
release : 8
bug_fixing : 1
protocol_id : 90
version_dy_hr_stat : 11
(1)pst_cpu6> mgr
lqSelect an objectqqqqqqqqqqqqqqk
x x
x Prefix Plan x
x Suffix Plan x
x Numbering Plan x
x PIN (Personal Ident.No.) x
x Private Call Profile x
x External Numbering Plan x
x Network Routing Table x
x Automatic Route Selection x
x -> Called Filtered Number x
x ATM Address List x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
x x
x Prefix Plan x
x Suffix Plan x
x Numbering Plan x
x -> Automatic Route Selection x
x Called Filtered Number x
x x
lqSelect an objectqqqqqqqqqqqqk
x x
x -> ARS Route list x
x ARS Schedule x
x ARS Calendar x
x Numbering Command Table x
x Authoris.Code Table x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
lqARS Route listqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x -> Go down hierarchy x
x Consult/Modify x
x Consult/Modify Overview of Object x
x Create x
x Create Overview of Object x
x Modify x
x Modify Overview of Object x
x Delete x
x Facilities x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
lqSelect an objectqqqqqqqqqqk
x x
x -> ARS Route x
x Time Based Route List x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqj
lqARS Routeqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x -> Consult/Modify x
x Create x
x Modify x
x Delete x
x Facilities x
x x
lqConsult/Modify: ARS Routeqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x << All instances >> x
x [ Set filters ] x
x [ Select attributes ] x
x x
x Instance (reserved) : 1 x
x ARS Route list : 9 x
x Route : ------------ x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
x x
x [ Set filters ] x
x x
x x
lqConsult/Modifyqqqqqqqqqqqk
x x
x running ... 2 x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqj
lq[ 2 ] Instances: ARS Routeqk
x x
x -> 1 x
x 2 x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
lqConsult/Modifyqk
x x
x running ... x
x x
mqqqqqqqqqqqqqqqqj
x x
x 1 x
x -> 2 x
x x
lqConsult/Modifyqk
x x
x running ... x
x x
mqqqqqqqqqqqqqqqqj
x x
x ARS Route x
x -> Time Based Route List x
x x
lqTime Based Route Listqqqqqqqqqqqqqqqqqk
x x
x Create x
x Modify x
x Delete x
x Facilities x
x x
lqConsult/Modify: Time Based Route Listqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x [ Set filters ] x
x x
x Time Based Route List Id : ------------ x
x x
x x
x running ... 2 x
x x
lq[ 2 ] Instances: Time Based Route Listqk
x x
x -> 1 x
x 2 x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
lqConsult/Modifyqk
x x
x running ... x
x x
mqqqqqqqqqqqqqqqqj
x x
x Time Based Route List Id : 1 x
x x
x Time Based Route x
x x
x [ Add ] [ Remove ] [ Next ] [Previous] x
x x
x x
x Route Number : 1 x
x Waiting Cost Limit : -1 x
x Stopping Cost Limit : -1 x
x x
x x
x 1 x
x -> 2 x
x x
lqConsult/Modifyqk
x x
x running ... x
x x
mqqqqqqqqqqqqqqqqj
x x
x 1 x
x -> 2 x
x x
lqConsult/Modifyqk
x x
x running ... x
x x
mqqqqqqqqqqqqqqqqj
x x
x Time Based Route List Id : 2 x
x x
x x
x x
x x
x Route Number : 2 x
x x
to check
Welcome to pst_cpu6
login: mtcl
Password:
Release:
DELIVERY i1.605
Country: dz
Cpu: c7s2
ACD VERSION
release : 8
bug_fixing : 1
protocol_id : 90
(1)pst_cpu6> mgr
x x
x Prefix Plan x
x Suffix Plan x
x Numbering Plan x
x x
x x
x Prefix Plan x
x Suffix Plan x
x Numbering Plan x
x x
x x
x ARS Schedule x
x ARS Calendar x
x x
x x
x Consult/Modify x
x Create x
x Modify x
x Delete x
x Facilities x
x x
x x
x -> ARS Route x
x x
x x
x Create x
x Modify x
x Delete x
x Facilities x
x x
x x
x [ Set filters ] x
x x
x x
x x
x [ Set filters ] x
x x
x x
x x
x running ... 2 x
x x
x x
x -> 1 x
x 2 x
x x
lqConsult/Modifyqk
x x
x running ... x
x x
mqqqqqqqqqqqqqqqqj
x x
x 1 x
x -> 2 x
x x
lqConsult/Modifyqk
x x
x running ... x
x x
mqqqqqqqqqqqqqqqqj
x x
x ARS Route x
x x
x x
x Create x
x Modify x
x Delete x
x Facilities x
x x
x x
x [ Set filters ] x
x x
x x
x x
x running ... 2 x
x x
x x
x -> 1 x
x 2 x
x x
lqConsult/Modifyqk
x x
x running ... x
x x
mqqqqqqqqqqqqqqqqj
x x
x x
x x
x x
x x
x x
x x
x 1 x
x -> 2 x
x x
lqConsult/Modifyqk
x x
x running ... x
x x
mqqqqqqqqqqqqqqqqj
x x
x 1 x
x -> 2 x
x x
lqConsult/Modifyqk
x x
x running ... x
x x
mqqqqqqqqqqqqqqqqj
x x
x x
x x
x x
x x
x x
