Stellar 1101 signal is not stable
sirmanhhung
Post by sirmanhhung »
Hi Guy,
I have a issue with stellar in enterprise mode.
The RF signal broadcast by the SSID fluctuates too much and sometimes completely disappears causing low throughput and client disconnections.
Below is the graph of signal captured in lab AP showing signal disappearance on WiFi analyzer tool Net Spot.
As you can see:
-SSID Omni-Stellar is older firmware
-SSID Test has newest firmware (3.0.3.1045)
Signal 5Ghz is more stable on above ssid
Any idea is very appreciate
benny
Re: Stellar 1101 signal is not stable
Post by benny »
Can you confirm if you use "Background Scanning" in your RF Profile?
Return to “OmniAccess Stellar Enterprise”
