Topology:
T1 from LEC - <7705 1/1/2> - <7705 1/2/7> - <Cisco 3750> - <IP Network> - <Cisco 3750> - <7705 1/2/7> - <7705 1/1/2> - Customer T1 handoff
The SDP opr mode is down.
Config from site A:
echo "Port Configuration"
port 1/1/2
description "Framed ESF Test"
tdm
ds1
clock-source adaptive
channel-group 2
encap-type cem
timeslots 1-24
no shutdown
exit
no shutdown
exit
exit
no shutdown
exit
echo "Service Configuration"
service
customer 1 create
description "Default customer"
exit
sdp 200 gre create
far-end 192.168.1.1
path-mtu 1400
keep-alive
shutdown
exit
no shutdown
exit
cpipe 888 customer 1 vc-type cesopsn-cas create
service-mtu 1300
no shutdown
exit
exitCode: Select all
port 1/1/2
tdm
ds1
channel-group 2
encap-type cem
timeslots 1-24
no shutdown
exit
no shutdown
exit
exit
no shutdown
exit
service
customer 1 create
exit
sdp 200 gre create
far-end 192.168.1.2
path-mtu 1400
keep-alive
shutdown
exit
no shutdown
exit
service-mtu 1300
no shutdown
exit
exitSome observations I've had:
From the Cisco I can ping the 7705 with 1546 sized packets
From the 7705 I can only ping the Cisco up to 1518 sized packets (How do I get this to ping it at 1546 bytes?)
Thank you
