4029 dont accept number programming
pcx-amateur
Post by pcx-amateur »
Hey everyone,
let me discribe my problem: we have the Alcatel 4029 in our company. I patched from the tlephone system to the telephone. Now the telephone asks for programming the number which this telefon should have. If a take off the telephone receiver and type in the number, nothing happens and the telephone repeat the request to take off the telephone receiver and type in the Telephone Number. By the way, the number is created on the telephone system and the adresses are set to 255 (so this number is not assigned to any telephone).
Any one have an idea what can i do?
Kind regards.
Re: 8029 dont accept number programming
the set type is correct ?!
and what happens if u assign to it a physical adress of corse an UA free adress
Eliott
Re: 4029 dont accept number programming
Post by Eliott »
Try to type number and 0000 to register
mdhussainvlr
Post by mdhussainvlr »
mdhussainvlr
First when you press any key itwill show press a key to put into service after you can dial the desired extension number created in the system followed by 0000
HCM_Citty
Post by HCM_Citty »
you have sure that licenes for configuration digital extension.
pcx-amateur
Sorry for the late reply.
I'm not 100% sure, but if I remember correctly, we did indeed run out of licenses for the digital extensions.
Thank you.
