Hi Guys...
Could any one help me please to configure trunk port between two switches 6560..
Command VLAN xx 802.1q 1/1/16 isn't supported...
Where xx is the VLAN I want to tag and 1/1/16 is the port I want to configure as trunk port.
Thanks in advance...
Configur trunk port
devnull
Re: Configur trunk port
read manual?
6560 is AOS7/8
So try:
vlan 1 members port 1/1/13-14 tagged
vlan 2 members port 1/1/17 tagged
vlan 3 members 1/1/20 untagged
6560 is AOS7/8
So try:
Enwary
thanks for replay,,
what I understand from the manual that these commands are used to add ports to vlans..
I am familiar with cisco but not yet with Alcatel..
In cisco to configure trunk port the following commands are used:
interface g0/1
switchport mode trunk
Switchport trunk allowed vlan xx
what is the equivalent commands in Alcatel...
interface g0/1
devnull
As i posted.
This is not cisco so you have to add all vlans you want to allow as tagged member.
There is no command
"switchport mode trunk" which allows all configured vlans automagically. Alcatel does it the otherway round -> enable each vlan you need.
More work, but better control.
Want to have 3 vlans + native would be:
vlan 10 member port 1/1/1 untagged
vlan 2 member port 1/1/1 tagged
vlan 3 member port 1/1/1 tagged
vlan 4 member port 1/1/1 tagged
-> Port 1/1/1 is now a trunk with tagged 2,3,4 ands untagged (native) vlan 10
There is no command
Enwary
Many thanks...now I get it and understand how it works...
thanks again...
thanks again...
