Disable Telnet & Ftp
raylence1
Post by raylence1 »
Hi All
I have a client that would like telnet and ftp disabled on their OXE running on release 12.1 when on their network.
Please advise if it possible to disable these two features?
Re: Disable Telnet & Ftp
No...what you can do is enable security, so telnet and ftp goes secure mode, ssh and sftp.
tgn
Post by tgn »
also you can configure the trusted host feature.
with this only specified hosts can connect with telnet and ftp/ssh and sftp.
regards...
oldboy
Post by oldboy »
Be aware if you have 8770 and you use SSH and SFTP you need to buy security lock for the application
