A4400 upgrade release 9.1 to release 12
maphi
Post by maphi » 26 Mar 2018 07:02
I try to upgrade the pbx to release 12 but my cpu reboot always.
I tried to start without IO2N but nothing is changed.
The bios is good.
Thx
Re: A4400 upgrade release 9.1 to release 12
Post by vad » 27 Mar 2018 00:48
What is your question? Competition - who is the first to guess the right answer?
Some description - CPU type, some problems during upgrade, reason for reboot (logs, incidents)...
oldboy
Post by oldboy » 27 Mar 2018 01:15
vad wrote:
27 Mar 2018 00:48
Hahahahaha was thinking the same thing.
Is it a new cpu or new harddrive as this is required fro Rel 12....???? i will keep guessing!
maphi
Post by maphi » 17 Apr 2018 02:39
it is a cpu 7-2 (oud board) with a new HD
Post by haroun » 17 Apr 2018 12:56
bios! new bios even os has changed from rhlE to Centos
maphi
Post by maphi » 18 Apr 2018 02:48
the bios is already new... of course
the cpu reboot always just after the putting of the database of the customer
oldboy
Post by oldboy » 18 Apr 2018 04:40
When you took the DB off the 9.1 system did you do a recover of the DB?? using fichges?
Post by vad » 18 Apr 2018 23:32
You install r12 - CPU works Ok?
You restore (via swinst) old database.
You load new OPS files.
You set autostart and reboot CPU.
And after - your CPU rebooted again (when DHS3 started)?
1 - show log/incidents
2 - in old database IO2N declared and now physically removed?
maphi
Post by maphi » 20 Apr 2018 09:28
I will try next week thx
Return to “Software Loading”
